Go to Post "Why do it the easy way when you can do it the hard way?:rolleyes:" - EricH [more]
Unread 22-01-2009, 17:24
GunfighterJ's Avatar
GunfighterJ GunfighterJ is offline
AKA: Joseph
FRC #2450 (RaiderBots)
GunfighterJ is an unknown quantity at this point
Question Labview toggle switch
is there anyway to take a joystick button and run it through a vi where it will do one function. Then go through some switch and do another function? Is there some sort of "switch" vi?
Unread 22-01-2009, 17:46
TotalChaos's Avatar
TotalChaos TotalChaos is offline
AKA: Austin
FRC #2837 (Freebird Robotics)
TotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud of
Send a message via MSN to TotalChaos
Re: Labview toggle switch
The short answer is yes.
I'm not sure there is one specific VI that does what you want, but it would certainly be possible. If I'm understanding you correctly you want a button that when pressed switches from doing one thing to another and doesn't change until the button is pressed again. If that is what you mean then you could check out the VI attached as an example of one way to do this. There is documentation of what I did on the block diagram in the VI.
- Austin
The 39th Aero Squadron - Team 39! (Visit our website!)
Team Role: 3 Years as Driver - College Student/Mentor!
Freebird Robotics - On a 1 year hiatus! (Visit our website!)
Arizona 2009: Semifinalists! (69 and 498), Delphi "Driving Tomorrow's Technology" Award
Unread 23-01-2009, 02:31
s0crates s0crates is offline
s0crates is on a distinguished road
Here's what I wrote to solve that problem. toggle2.vi is a subvi that takes one input - a boolean value of whether or not the non-toggle switch is pressed. When it detects a change from 0 to 1 or from 1 to 0, it toggles the output. It does this by storing the previous input.
-jonathan
Pigmice Team 2733
Unread 23-01-2009, 14:45
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
Attached is a little code that implements this. As with every programming language this is one of about 100 ways of doing this...
Let me know if you have questions about how this works.
Cheers,
Mark
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
Unread 23-01-2009, 14:49
BLAQmx's Avatar
Software Engineer
Opps I noticed a mistake in my attached code. This attachment has is correct.
Unread 07-02-2009, 12:14
AKA: Joseph
- Austin
That looks complicated. But I think I can work that in to our code. Thanks for the help.
Unread 07-02-2009, 12:48
AKA: Joseph
- Austin
Unread 13-02-2011, 11:53
Seth Moulton's Avatar
Seth Moulton Seth Moulton is offline
iTzS∃th
AKA: Seth
FRC #0134 (Pembroke Spartans)
Seth Moulton is an unknown quantity at this point
Send a message via AIM to Seth Moulton
That actually wouldn't work, because you would need to put the "enum" to your driver station, which is against the rules. You need a toggle switch, so that when you hit the button once, it will initiate something, but when you release the button (causing the boolean to read "false") that same function will stay initiated until you hit the button again...
Unread 13-02-2011, 18:03
Bit funny, it's been 2 years since I was part of this and I had totally forgotten about this message board until I got an email notification about a thread response.
You generally should let old threads (3+ months?) die a natural death. I'm not certain how much has changed, but all this info *was* accurate as of '09. Bringing threads like this to the top of the list just serves to confuse people with old information.
It is known as "necroing" and is widely frowned upon.
Need Help Wiring Micro Switch/Limiting Switch Windward Electrical 2 07-02-2006 18:26
toggle switch Windward Programming 31 27-01-2006 22:38
Toggle switch with pneumatic The yellowdart Programming 2 21-02-2005 14:08
Pneumatics on a toggle switch Idaman323 Programming 3 15-02-2005 18:42
3 way toggle switch programming LeadRiccardoT Programming 3 17-02-2003 02:02
