Go to Post Now, what we really need is a big spotlight in the sky that shoots out the letters "CD" so Brandon knows to come running to the server cave ... - mtrawls [more]
Unread 23-01-2009, 15:47
Zellboy Zellboy is offline
FRC #1203
Zellboy is an unknown quantity at this point
Connections to Driver Station
I'm trying to hook up LED's and switches to the input and output of the driver station. When we send the signal to input it gives us a pulse. Any solutions?
Unread 23-01-2009, 16:24
Re: Connections to Driver Station
What "signal" are you sending, and where are you seeing the "pulse"?
Remember that the Driver Station inputs don't have a pullup (or pulldown) resistor. You can't just connect a switch to ground (or to +5) and have it work. The input won't work reliably if left floating. You need to either switch it between ground and +5, or attach a resistor (10k or so) to +5 and use a switch to ground.
Dead Driver Station? tdeprince FRC Control System 3 12-02-2009 12:14
Driver Station Login Mr-Shutter FRC Control System 2 12-01-2009 23:36
2nd Driver Station bcharbonneau General Forum 2 09-01-2009 14:19
Driver Station Help.. 1708xMr.Roboto FRC Control System 8 22-12-2008 15:24
Driver Station Setup?? Team 1708 Dave Programming 9 19-12-2008 23:09
