Go to Post Either way, FIRST works. You just have to keep the big picture in mind. - Lux [more]
Unread 17-01-2009, 13:37
frank.pendzich's Avatar
frank.pendzich frank.pendzich is offline
Mr.P
AKA: Mr. P
FRC #3011 (RoboWarriors)
frank.pendzich is an unknown quantity at this point
Festo Solenoid Doesn't Work
The Festo solenoid that came with our KOP works manually but not electrically. Under 45 PSI, the LED (yellow) indicator turns on but the state of the solenoid doesnt change.
There are many messages claiming similar problems and recommend an SMC replacement. We've been searching for hours for a direct replacement for the Festo solenoid and a distributor without luck.
Can anyone provide a SMC partnumber and source of supply for a direct replacement for the KOP Festo solenoid?:
Unread 17-01-2009, 15:37
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Festo Solenoid Doesn't Work
The Festo Valve is a self piloted valve and requires 30PSI minimum to activate. This is not a problem and is as designed.
___________________
- Tennyson, Ulysses
Unread 18-01-2009, 04:32
Mr.P
AKA: Mr. P
Daniel... We're putting 45 PSI into it and it's not changing states. I'm still looking for a suitable substitute from SMC.
Unread 18-01-2009, 09:42
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Ours was DOA as well.
SMC SY or SV3000 series are nice little valves.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 18-01-2009, 09:58
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Sorry, missed that.
SMC telephone number 1.800.SMC.SMC1 (To find a local distributor. I cannot read german, so this is the american site telephone number).
SMC Valve configurator
Remember to meet all <R69> requirements.
___________________
- Tennyson, Ulysses
Unread 18-01-2009, 10:10
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The SMC valves we recieved in previous years KOP were not a direct replacement for the Festo valve, but would work in place of them with a little bit of effort.
Sub Base, 1/8" ports, SY3000-27-1T
Single Solenoid Valve, SY3140-6H-S
Double Solenoid Valve, SY3240-6H-S
Unread 23-01-2009, 15:47
STL's Avatar
STL STL is offline
AKA: Sean O'Grady
FRC #1189 (The Gearheads)
STL has a spectacular aura aboutSTL has a spectacular aura about
Dear Teams,
My name is Sean O'Grady. I'm the field supervisor at the ST. Louis regional and a Festo employee. In addition to the helpful troubleshooting tips that are listed above, assure that the pressure that is applied to the valve is connected to port 1. If the pressure is connected to port 3, the valve will seem to function normally with the manual override, but not with the solenoid. If you're still experiencing problems, Festo product support engineers are available to help you at 866-GO-Festo (7AM - 7PM CST). If they're not able to resolve your problem over the phone, they'll arrange to ship a replacement valve to you right away.
Festo is dedicated to the mission of First, which why we have continued to sponsor the program during these difficult economic times.
Good luck!
Sean O'Grady
Unread 23-01-2009, 16:55
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by STL View Post
Dear Teams,
Good luck!
Sean O'Grady
Sean,
First off, welcome to Chief Delphi. It's good to see sponsors supporting FIRST, and helping out here on CD.
Secondly, thank you for the piloting information. I kinda suspected that the pilot was only on port 1 but I wasn't sure. I've always felt that the Festo valves were good (even though I believe the orifice is oversized for most of our applications) valves for FIRST.
Hopefully no one will need the support line, but it's great to know it's there.
Thanks for the support and good luck at STL.
___________________
- Tennyson, Ulysses
Unread 23-01-2009, 17:43
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
We have a DOA one as well. The LED lights up, but it does not switch on. There is no mechanical click at all. This was tested using 45+PSI.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 30-01-2009, 22:26
Bob Holmstrom Bob Holmstrom is offline
FRC #2411
Bob Holmstrom is an unknown quantity at this point
Team 2411 had problems getting Festo solenoids to operate also. What we found is that the wiring information provided seems to be wrong. The documentation suggests that power should be connected to terminals 1 & 2. Our solenoids work if power is connected to terminals 1 & 3. We don't know if this is a universal solution, but it worked for us.
Bob
Unread 30-01-2009, 22:36
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
http://www.pneumaticsfirst.org/TheGame/FESTO2004.htm
That is the best datasheet for the Festo that I have ever found and been using it for several years. . I have also found that the Solenoid does not like to have the cylinder hooked up backwards. (Keep the back of the cylinder on port 4)
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 31-01-2009, 10:08
Team2883's Avatar
Team2883 Team2883 is offline
FRC #2883
Team2883 will become famous soon enoughTeam2883 will become famous soon enough
We also had a issue but was resolved after changing the wiring as mentioned above. Since then we have not had an issue.
Fighting Rednecks
Team 2883
Unread 07-02-2009, 13:00
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
Our work fine if we connect power to 1 and 2. a piece of advice: make sure your solenoid breakout is receiving power. We spent a day and a half trying to figure out why it's not working, when the problem was that we forgot a breaker.
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 09-02-2009, 23:27
Dr. Manhattan Dr. Manhattan is offline
Atomic Reconstruction
AKA: Joe Bakke
FRC #2521
Dr. Manhattan is on a distinguished road
Send a message via AIM to Dr. Manhattan
Team 2521 is having the same problem as well. We've tried switching to 1 && 3, all of our wiring is correct, the breakout is receiving power, and the pneumatics are correct as well. We have no clue what to do now, anyone have suggestions?
Unread 10-02-2009, 08:03
camtunkpa camtunkpa is online now
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
Bob
I will second the pins 1&3 connection. 222 had the same exact problem on both of our festo valves.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Festo Single solenoid JP_1163 Pneumatics 4 24-02-2006 15:07
Festo solenoid wiring? computhief263 Pneumatics 1 15-02-2004 12:25
festo solenoid maxgebhardt Pneumatics 19 21-01-2004 23:06
Festo valve.... why wont it work? CHSguard72 Pneumatics 3 08-02-2003 19:07
sensor doesn't work PBoss Programming 7 29-01-2003 18:39
