Go to Post The point of outreach isn't to "win" a "game" so I'm not sure what you hope to achieve with such a concept. The idea of "beating" another team in terms of outreach is fundamentally flawed. - dcarr [more]
Unread 23-01-2009, 17:36
the_waterboy the_waterboy is offline
FRC #1095
the_waterboy is an unknown quantity at this point
Color template not loading?
We are trying to use the camera to track the pink flag, just as a test of our camera's tracking ability. We went through NI Vision Assistant and created a script to locate the color pink in an image. We tested it in Vision Assistant using different images and it successfully finds pink. When we try to use the code on our Robot Project, using the sub-VI created by Vision Assistant, we noticed that the program is not loading the template. We noticed this by setting up a probe at the wire coming in for the template and receiving a blank screen. Is anyone else having this problem, or know how to fix it?
So what if I'm crazy?
Unread 23-01-2009, 17:44
drkiraco drkiraco is offline
FRC #1747
drkiraco will become famous soon enoughdrkiraco will become famous soon enough
Re: Color template not loading?
You have to upload your template file to the cRIO via FTP. I don't remember exactly where, but there is a document somewhere describing how to do this. Try first's website or ni.com and you should find it.
Unread 23-01-2009, 18:08
FRC #1095
Thanks for the information, but I can't find any information about FTP with the cRio. Does anyone know how to do this or have a link to get to instructions on how to do this?
Unread 23-01-2009, 18:45
FRC #1747
found it
http://decibel.ni.com/content/docs/DOC-3032
Unread 23-01-2009, 19:28
FRC #1095
Thank you! We finally got color tracking.
Invalid color template image? hellochar NI LabVIEW 3 18-01-2009 17:05
[OCCRA]: Template iwanttodunk OCCRA Programming 14 29-10-2008 21:02
Does the Trackball Color Match your team Color??? ZInventor Kit & Additional Hardware 14 07-03-2008 20:09
Template Project Astronouth7303 Programming 10 30-05-2004 20:05
Pictures not loading sanddrag CD Forum Support 32 11-10-2002 01:55
