Go to Post After assisting with the animation last year I realized how cool and useful Inventor was and I started flirting with it. Half a year later I think I have lost all possibility of ever having a girlfriend, and frankly I don't care because I would definately bare the child of this program. - negfrequency [more]
Unread 23-01-2009, 20:02
cmh0114 cmh0114 is offline
AKA: Cam H
FRC #0217 (Thunderchickens)
cmh0114 will become famous soon enoughcmh0114 will become famous soon enough
Labview Rookie Question -- Motors
I'm just learning LabView, and I have an extremely basic question -- how do you run a motor using LabView? I know that it's supposed to be run through a serial port, but how do you write a program to output in that way? I used several different tutorial sites, but none of them addressed this, and I can't find it through Google. Also, I'm not exactly a natural-born programmer. Any help is appreciated.
Unread 23-01-2009, 20:41
markulrich's Avatar
markulrich markulrich is offline
Head Captain and LabVIEW Programmer
FRC #2129 (Ultraviolet)
markulrich has a spectacular aura aboutmarkulrich has a spectacular aura about
Re: Labview Rookie Question -- Motors
Motors can be run many different ways; for the FRC competition, they are controlled via PWM signals from the Digital Sidecar (not through a serial port).
I suggest making sure you have the FRC version of LabVIEW installed (from a disk that came in the Kit of Parts), along with the update. Use the FRC NI training materials to learn how to control a motor using the WPI Robotics Library sub-vis. Start with the default project, make sure it works, and then edit.
Unread 23-01-2009, 20:44
Kahn! Kahn! is offline
FRC #1379
Kahn! is an unknown quantity at this point
There are also several run-able example vi's in the National Instruments/Labview/examples/FRC (-ish) folder.
Example LabVIEW Apps - Dashboard, CMUcam2 and Motors DanDon LabView and Data Acquisition 3 29-01-2009 22:13
LabView: Questions of a Rookie assaf2b NI LabVIEW 1 17-01-2009 12:14
Labview 'Invert Flag' for motors ksquared NI LabVIEW 1 12-01-2009 21:35
Labview with Four Motors brianc217 General Forum 3 04-01-2009 23:58
Labview with Four Motors brianc217 NI LabVIEW 0 04-01-2009 11:52
