Go to Post I've never seen a spam bot edit posts before - Vikesrock [more]
Unread 22-01-2009, 20:16
PackersFan PackersFan is offline
PackersFan is an unknown quantity at this point
[FTC]: [FTC]: RobotC Template Problem (causing an FMS issue) and Potential Servo Prob
For some reason, the new joystick driver has some issues. We followed the online tutorial and installed the new one, but the new joystick driver causes connection issues with our NXT. We cannot connect via bluetooth with it at all, and downloading with a USB can be buggy as well. I know the problem is joystick driver related because we used the exact same code (just out of the template) but we used the old joystick driver (which we renamed) and the robot preformed just fine. This means that we cannot run the FMS at all, and we cannot test the new templates as we can only run the FMS when connected via bluetooth.
And then as another issue, we have a robot that struggles to pick up more then 8 pucks in a plexiglass basket using 6 servos. Could there be any issue that might be causing a problem, or is this just the limited power of these servos?
Thank you so much for your help.
Unread 23-01-2009, 08:29
jbbjjbt jbbjjbt is offline
VRC Coach
AKA: Jon T
VRC #0177 (Twisted Botz)
jbbjjbt is an unknown quantity at this point
Re: [FTC]: [FTC]: RobotC Template Problem (causing an FMS issue) and Potential Servo
I can't help with the RobotC issue, but as far as the servos, we have a bucket with 4 servos to move 8-10 pucks into the 12" high goal. It is very difficult to get 4 servos in sync with each other so 6 would be even harder. When they aren't in sync, they fight each other and won't due the job you're trying to do. We also find the servos dont last very long and have to be replaced often. So check to make sure your servos still work. Another issue is the moment arm for your basket, if you are trying to get the pucks into the high goal, servos probably don't have enough umph unless you use counterweights or some way to get leverage.
Jon Thompson
Coach
VRC 177 Twisted Botz
Sponsored by FRC 122
NASA Knights
Unread 23-01-2009, 09:52
Thanks! Yeah, we're only going for the circle goal. How would we go about syncing the servos? We have checked to make sure that they all work, but I will keep that in mind.
Unread 23-01-2009, 20:55
VRC Coach
AKA: Jon T
What we do is
1) Move our bucket to the first position and make a mark on each of the servo holders
2) Move our bucket to the second position and make another mark of a different color on each of the servo holders
3) Take off the bucket and adjust the servos (Numbers in move servo command) until each one goes to the marks when told
4) Put the bucket back on and test. You may have to turn on the robot and run the servos to one position and then attach your bucket to get it lined up. The servos should be nearly silent if the numbers are correct. If there is alot of vibration or they move really jerky try again.
Jon Thompson
Coach
NASA Knights
Unread 24-01-2009, 19:11
Our servos are fastened to each other. They don't twitch, but they do vibrate and make noise. Should we try to sync them differently or would this still work?
Unread 24-01-2009, 21:37
ttldomination's Avatar
Sunny
Are your servos facing each other? Like []- -[]. If they are, you must know that the values are flipped. and the two servos are resisting each other. For one servo, 255 is up, and for the other, 255 is down.
Is this how you have them?
1648: 2013-2014
5283: 2015
Unread 24-01-2009, 22:01
The servos are facing each other and they are inverted.
Unread 25-01-2009, 12:04
Sunny
Hm. THen it could simply be that they are carrying too much weight. We had this issue with our bot, where the servos would hum and twitch, but the arms were just too heavy.
1648: 2013-2014
5283: 2015
Unread 25-01-2009, 12:19
DISCLAIMER: There is an 85% chance that I am completely wrong.
Servos are nominally position controlled, but you want them to add their force together. To me, that indicates that you want to make them force controlled.
If you add a bit of series elasticity (a rotary spring), you might be able to add enough slop so that they aren't fighting each other so stiffly.
I'd prefer if a MechE chimed in here. It just seems analagous to a few things I do as a SparkE. For example, lets say that I need to use several linear regulators in parallel. These are nominally ideal voltage outputs - very stiff. However, they will each have a slightly different idea of what 5V is, so one of them will take over. One solution is to add small resistors afterwards to ensure load balancing. This takes the very stiff controls and give them a more forgiving slope.
Unread 25-01-2009, 20:21
Originally Posted by jbbjjbt View Post
What we do is
Could you go into more detail about that method? What I'm getting from the first and second positions is the starting point and the ending point, is that right? Also, where do the marks go and what purpose do they have?
Unread 26-01-2009, 19:51
gdo's Avatar
gdo gdo is offline
Never too much duct-tape ;)
AKA: Patrick
FTC #0001 (Team Unlimited)
gdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to behold
Send a message via AIM to gdo Send a message via MSN to gdo
For our servos we are doing 2:1 gearing, we got the spacing to work out just right. Here's a picture of it. There are 1 pair of servos on each side of the basket. With this method, we managed to get the servos at exactly the same position, for this side 255, and then drop the arm ontop, the servos have little problem with keeping at the same position, and so far we have had no problem w/ torque either.
Sorry for the quality, my camera is MIA so I had to use my webcam on my laptop..
FTC #1: http://unlimited.syraweb.org
Got any question for me; AIM, MSN or PM me
Unread 26-01-2009, 21:25
VRC Coach
AKA: Jon T
You are correct. The marks are just on the sides of the servo holders so you know where the servos go to with the bucket off.
We find the even with two servos oriented the same, the number for a position may be up to 20 or so different for the two different servos.
Also you don't want to drive the servos clear to the limits (1 or 255) if the arm is mechanically stopped sooner. We were driving our servos to 255 but the bucket hit the goal at 220 and this was breaking the servos.
Jon Thompson
Coach
NASA Knights
[FTC]: LabVIEW Programming Template for FTC Team 288 FIRST Tech Challenge 30 06-02-2010 17:49
[FTC]: RobotC Template gdo FIRST Tech Challenge 14 10-11-2008 06:26
[FTC]: First problem with FTC and LabView.....? PhilBot FIRST Tech Challenge 5 07-11-2008 10:36
[FTC]: FTC Controller Station Connectivity (Bluetooth and USB) Issue jbbjjbt FIRST Tech Challenge 6 05-11-2008 11:49
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
