Go to Post however, if i tried it i would probably end up setting my hair on fire - Henry_Mareck [more]
Unread 23-01-2009, 15:21
zackcool123's Avatar
zackcool123 zackcool123 is offline
FRC #1886
zackcool123 can only hope to improve
Exclamation AHHHH!!!!!! LOST CAMARA POWER CABEL
doe anyone know if we can make a power cord for the camara without the orignnal?????
Unread 23-01-2009, 15:23
Re: AHHHH!!!!!! LOST CAMARA POWER CABEL
Of course! A search through the CD files will reveal the Radio Shack part number of the camera power connector or you can just take the camera with you to the local electronics house and match it to one they have in stock. Add a pair of wires and you back in business.
Unread 23-01-2009, 21:27
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
The kop comes with two camera power supplies. One with the camera, one in a sepperate bag.
Phil Malone
http://www.GEARSinc.org
Unread 25-01-2009, 17:46
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
That being said, there are pros and cons to each.
One that came from axis in box, the pro of it is the barrel connector fits extremely well, the con is the negative uses the shield which isn't the best solution for stuffing it into a wago connector (ferrules help this)
The baggy on has the pro of being two separate wires so you don't have to pull away the shield, the con being that the barrel connector didn't fit in the camera quite as well as the single conductor.
Lost Wago power connector 734 102 falconmaster General Forum 14 06-01-2009 13:01
15 pin cabel and connector of OI mcf747 Control System 14 27-02-2008 08:51
Camara Emma General Forum 1 17-01-2005 11:02
Ahhhh! I've had it with 3dstudio max! AnnyRob 3D Animation and Competition 6 29-01-2002 11:23
ahhhh David Kelly CD Forum Support 3 25-10-2001 22:15
