Go to Post My robot is my significant other. It makes me happy, sometimes it makes me sad, i wish it would lose some weight but it is always there for me. - rachelholladay [more]
Unread 23-01-2009, 21:10
PHSRobotics PHSRobotics is offline
FRC #2135
PHSRobotics is an unknown quantity at this point
Joystick Movement
Necisito help with the joystick movement. My team wants to figure out how to get the joystick movement values to output in LabVIEW. Nothing we have found has helped us.
Unread 23-01-2009, 22:42
TotalChaos's Avatar
TotalChaos TotalChaos is offline
AKA: Austin
FRC #2837 (Freebird Robotics)
TotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud of
Send a message via MSN to TotalChaos
Re: Joystick Movement
In the Basic Framework the have outputs in the code already. I assume you mean you want to get the data from the Joystick axis in which case you could use the Get Axis VI. (WPI Robotics Library > DriverStation > Joystick > GetAxis.VI)
If you mean you want to see the values in real-time on the front panel, then you could just right click on the output node and select Create > Indicator.
I hope that helps!
- Austin
The 39th Aero Squadron - Team 39! (Visit our website!)
Team Role: 3 Years as Driver - College Student/Mentor!
Freebird Robotics - On a 1 year hiatus! (Visit our website!)
Arizona 2009: Semifinalists! (69 and 498), Delphi "Driving Tomorrow's Technology" Award
New Code - No Movement Guarana Programming 1 13-02-2008 20:17
Arm movement program1 Programming 3 28-01-2008 11:49
Movement Hunter1539 Rules/Strategy 4 09-01-2008 22:06
PWM translates to movement? Generalx5 Electrical 18 15-07-2007 23:23
