Go to Post I have a bobble head? - Koko Ed [more]
Unread 23-01-2009, 23:21
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
Problem with deploying a stand-along application
We are trying to build a stand-alone application so that our bot can run our program over a wireless connection. The manual states to start a new real-time application under RT CompactRIO Target. However, the real-time application option isnt there. Only the Source Distribution option shows up. What are we doing wrong?
Unread 23-01-2009, 23:27
Re: Problem with deploying a stand-along application
Are you building this from scratch or using the Basic or Advanced Frameworks?
Did you start a new project from a blank vi?
Unread 24-01-2009, 00:04
FRC #2477
Yes, we started a new project using the basic framework. We also reinstalled Labview to make sure that we installed everything.
Unread 24-01-2009, 08:46
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
It probably means that you have not activated the full FRC development license. Or possibly when you did your last update it got un-activated (it's happened to me).
Go to Start/All programs and open the National Instruments node.
Select and run "NI License Manager".
Expand Local Licenses, Labview 8.5.1, Development System.
Is the "First Robotics Competition" box filled in yellow? It should be.
If not, double click it and follow the instructions. You'll need the License number that came with your original disks. This should re-enable the "Real Time" build option.
Phil Malone
http://www.GEARSinc.org
Unread 27-01-2009, 07:24
FRC #2477
This might seem weird, but the build stand alone application option shows up fine on an xp machine, but not the vista machine. On the vista machine it looks like everything is activated.
Problem deploying/running default code blaxbb FRC Control System 0 10-01-2009 11:59
Pics along with the avatar FF_1610_EMT Chit-Chat 2 07-03-2008 11:34
CMUCam2 LabVIEW Application problem itsdamoose LabView and Data Acquisition 1 09-02-2006 20:59
Issue with CMUCam2 Demo application Bio LabView and Data Acquisition 12 21-01-2006 16:08
All-Time PID Drive with Hall-effects: Coming along very nicely jdong Programming 6 05-02-2005 19:39
