Go to Post It doesn't matter if you write a thousand lines of code for a robot, if you didn't teach and/or inspire the HS students as you did it then you are not a mentor. - JamesBrown [more]
Unread 23-01-2009, 23:47
waterfreak#1's Avatar
waterfreak#1 waterfreak#1 is offline
nate
AKA: 6
FRC #1388 (eagle robotics 1388)
waterfreak#1 is an unknown quantity at this point
Send a message via Yahoo to waterfreak#1
Re: crab drive
how are you doing that does it work fine did you work out the variables
the passage below is false
the passage above is true
Crab Drive RMS11 Robot Showcase 46 05-09-2008 22:34
Crab drive question peter_p Technical Discussion 15 15-08-2008 15:18
Crab Drive nukelear1991 Programming 13 21-12-2007 18:02
Crab Drive Joe_Widen Technical Discussion 9 21-04-2006 21:50
Crab Drive Collin Fultz Technical Discussion 3 04-09-2002 16:35
