Go to Post “FIRST is your experience and you cannot let anyone else hinder what you can achieve.” - fuzzwaz [more]
Unread 23-01-2009, 11:29
programmr's Avatar
programmr programmr is offline
AKA: Face
FRC #0522
programmr is a jewel in the roughprogrammr is a jewel in the roughprogrammr is a jewel in the rough
Send a message via AIM to programmr
Unhappy Programming Joystick Buttons to toggle a motor on and off
Hello there, can someone please help? I want to use a joystick button to toggle on and off a motor. If logitech button 3 is pressed once, turn the motor on with a speed of .5 If the button number 3 is pressed again, turn the motor off. In this case, it would be controlled by joystick connected to usb port 3.
Attached is what i have so far. Any help would be greatly appreciated.
"I would love to change the world but no one will give me the source code"
Unread 23-01-2009, 16:50
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Programming Joystick Buttons to toggle a motor on and off
Joystick stick3(3);//obviously
Jaguar jag1(3);//PWM port 3
bool btn3state=false;
if (stick3.GetRawButton(3))
if (btn3state)
jag3.Set(0.5);
btn3state=false;
else
jag3.Set(0.0);
btn3state=true;
Watchdog.Kill();
Unread 23-01-2009, 20:30
LinuxMercedes LinuxMercedes is offline
Real men use Macs
FRC #1444 (Lightning Lancers)
LinuxMercedes is an unknown quantity at this point
One bug in your code, byteit101
if (!btn3state) //if the button has not been depressed
jag3.Set(0.5);
btn3state=true; //the button has been depressed
else
jag3.Set(0.0);
btn3state=false; //the button was clicked again
Otherwise, you'd click the button first to set the jag to 0, then the second click would set it to 0.5. Unless I missed something.
Unread 24-01-2009, 08:05
byteit101's Avatar
no, it is in an if else
if it was
if (btn3state)
jag3.Set(0.5);
btn3state=false;
else if (!btn3state)//always execute
jag3.Set(0.0);
btn3state=true;
it would be buggy, but if "if" is true, "else" is not executed
Watchdog.Kill();
Unread 24-01-2009, 09:10
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
This is how my team did it.
// this is all in our autonomous loop....
bool buttonUp = leftStick->GetRawButton(1);
bool buttonDown = leftStick->GetRawButton(2);
bool buttonStop= leftStick->GetRawButton(3);
float elevatorSpeed; // this is the speed of our elevator
if (buttonUP){
elevatorSpeed(1.0);
else if (buttonDown){
elevatorSpeed(-1.0);
else if (buttonStop){
elevatorSpeed(0.0);
ElevatorMotor1->Set(elevatorSpeed); // elevator motors one and two are
ElevatorMotor2->Set(-elevatorSpeed);// on both sides of our elevator
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
Unread 24-01-2009, 10:01
Eric Finn's Avatar
Eric Finn Eric Finn is offline
FRC #0166 (Chop Shop)
Eric Finn has a spectacular aura aboutEric Finn has a spectacular aura about
Send a message via AIM to Eric Finn
Even with that, it would not work properly, assuming this code is executed often enough.
bool btn3state=0;
bool pwm3state=0
//The motor starts at 0, each time we press the button it toggles between 0 and .5.
//The motor will only change once if the button is held down for multiple loops.
if(stick3.GetRawButton(3) && !btn3state) //if the button is pressed, but not held...
	btn3state = 1; //button is now being held
	if(!pwm3state) //if the motor is not moving
		jag3.Set(0.5);
		pwm3state=1; //the motor is moving
	else //if the motor is moving
		jag3.Set(0.0);
		pwm3state=0; //the motor is not moving
else if(!stick3.GetRawButton(3) && btn3state) //if we think the button is held, but it's not being pressed...
	btn3state = 0; //button is no longer held
With this, you have to release the joystick button in order to toggle the motor again. Without this, the motor will toggle many times, even with just a short tap of the button.
Remember, if that code is in a while loop, the variables should be declared *before* the loop. If the code is in a function, they should be static.
It always takes longer than you expect, even when you take into account Hofstadter's Law.
--Hofstadter's Law
Unread 25-01-2009, 17:47
WatersongX WatersongX is offline
AKA: Matthew Keen
FRC #1111 (Powerhawks)
WatersongX is an unknown quantity at this point
Send a message via AIM to WatersongX
May I reccomend a simpler system?
Assume the following variables:
Jaguar speedcontroller1
Joystick usb3
has been set up and initialized correctly
// with variable declarations (outside of main loop, so they don't reset every time)
bool togglestate = false;
bool lastu3b3state = false;
// somewhere in code (inside main loop, runs every time)
if ( lastu3b3state == true && usb3.GetRawButton( 3 ) == false ) togglestate = !togglestate;
speedcontroller1.Set( togglestate?0.5f:0.0f );
// at the end of the main loop, or at least after the button is done being used
lastu3b3state = usb3.GetRawButton( 3 );
joystick and extra buttons TEAM1949 Programming 3 18-02-2008 13:22
Toggle Motor On & Off Help..... programmr Programming 1 16-02-2008 11:15
Programming Extra Joystick Buttons Inverted Programming 2 08-02-2007 11:45
Programming motors with joystick buttons TMHStitans Programming 5 21-03-2005 21:07
joystick buttons and a quick question h0x4r Programming 2 17-02-2005 00:18
