Go to Post "If a student CAN do it, a student SHOULD do it." - Mr. Lim [more]
Unread 23-01-2009, 10:44
excel2474's Avatar
excel2474 excel2474 is offline
AKA: Aaron Stewart
FRC #2474 (Excel)
excel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the rough
Smile Lights On Compact Rio?
Are there lights on the Crio that have to be visible from a certain distance. Last year you had to be able to see certain lights on th RC.
"Find some thing you like to do and EXCEL at it with dilligence."
University of Notre Dame- Mechanical Engineering.
Unread 23-01-2009, 11:19
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Lights On Compact Rio?
I'm going to "teach you to fish" by giving you the standard "please read the rules" comment. Read Section 8 Robot Rules (link below) and get your own answer. It should be obvious.
http://www.usfirst.org/uploadedFiles...%20Rev%20E.pdf
Sorry for being harsh but all teams really need to be familiar with the game and robot rules. The robot inspectors will be very appreciative of teams that go through the rules and inspection checklist to ensure compliance BEFORE shipping your robot.
You'll need to re-read Section 8 every year since changes do occur.
Russ
Unread 23-01-2009, 11:22
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
In addition to reading the rules, a quick search of this forum will often turn up answers faster than waiting for a new response. I was able to find this thread, which is relevant to your interests:
http://www.chiefdelphi.com/forums/sh...ad.php?t=72392
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 23-01-2009, 14:22
excel2474's Avatar
AKA: Aaron Stewart
FRC #2474 (Excel)
Russ
My team mates did and said they didn't see anything about it. So, I thought I'd just double check.
Unread 23-01-2009, 14:24
excel2474's Avatar
AKA: Aaron Stewart
FRC #2474 (Excel)
Sorry, I didn't really think about searching for it.
Unread 23-01-2009, 15:38
excel,
You will find that you will need to see the LEDs on Crio as much as the inspection team and the field controls people. It will be neccessary for these people to see the LEDs in the event of a problem to help you diagnose the problem and a variety of other functions. See p14&15 of the linked document that Russ has provided. If any of the volunteers has a hard time seeing any indicator on your robot, it will make it difficult or near impossible to help you troubleshoot and you may be asked to move it. All indicators are there for your convenience so put them where they can be seen.
The robot signal light has a specification in R58...
<R58>
ROBOTS shall use the diagnostic Robot Signal Light provided in the Kit Of Parts. It must be mounted on the ROBOT such that it is easily visible while standing three feet in front of the ROBOT in the STARTING CONFIGURATION. The Robot Signal Light must be connected to the “RSL” supply terminals on the Digital Sidecar, which provides power and control for the light. The team has no direct control over the light and no programming is required.
Russ also provided this document in a different thread. It is an explanation of the RSL codes...
http://decibel.ni.com/content/docs/DOC-3120
Unread 23-01-2009, 16:08
excel2474's Avatar
AKA: Aaron Stewart
FRC #2474 (Excel)
excel,
<R58>
Ok, Thanks for that info.
Unread 23-01-2009, 17:18
I'd like to reiterate Al's comments - just because the rules don't require that the cRIO LEDs be clearly visible, it is BY FAR in your best interest to make sure that they're visible.
I like to think that there are RULES (for safety and fairness) and there are RECOMMENDATIONS (for better performance). Visibility of blinky lights is strongly RECOMMENDED. RSL visibility, on the other hand, is a rule since it can impact field personnel safety if not clearly visible.
Russ
Unread 23-01-2009, 17:44
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
On the other hand, if someone asks you to rearrange your robot simply because they want to be able to see cRIO lights in addition to the easily visible cRIO light, don't feel shy about refusing to do something not required by the rules. Especially if it's not actually causing you or anyone else a problem.
Unread 24-01-2009, 10:11
excel2474's Avatar
AKA: Aaron Stewart
FRC #2474 (Excel)
Let me get this straight. There is NOT a rule that says the lights on the compact rio must be visible. There is however a LED light that must be mounted so that it is clearly visible from the front of the robot. Correct?
Unread 24-01-2009, 10:25
Yes - the Panel Signal Device from the KoP (look it up on the checklist, it's also referred to as the RSL or Robot Signal Light) must be connected to either DSC's RSL port.
Russ
Unread 24-01-2009, 11:09
excel2474's Avatar
AKA: Aaron Stewart
FRC #2474 (Excel)
Russ
Ok, thanks. I saw that in the rules, but it doesn't say anything about the visibility of LED lights on the crio, correct?
Unread 24-01-2009, 11:27
There is no specific rule about being able to see the Crio LEDs from outside the robot, yet. However, no one would hide them. They are there for your convenience. If you have to plug into the Crio for programming and the LEDs are right next to the connectors, I don't see how you could mount the Crio so that the LEDs weren't visible.
Unread 24-01-2009, 11:35
excel2474's Avatar
AKA: Aaron Stewart
FRC #2474 (Excel)
Thanks for the reply. The crio is accessible, but there is a part over it that makes it not visible, but the part is easily removable for access to the crio.
Flashing compact rio? excel2474 Programming 3 06-01-2009 14:10
RIO update? Betty_Krocker General Forum 3 03-12-2008 07:46
New compact rio OI? excel2474 FRC Control System 8 28-10-2008 16:10
Compact rio question? excel2474 FRC Control System 2 07-10-2008 05:47
Compact rio not being able to use C kenethare Programming 47 10-09-2008 22:33
