Go to Post FIRST truly isnt about building robots, but allowing yourself to reach higher and farther than you ever could. - Brandon Holley [more]
Unread 24-06-2002, 01:11
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
LAST MINUTE Pneumatic Question
Posted by Chris Orimoto at 2/20/2001 5:10 PM EST
Student on team #368, Kika Mana, from McKinley High School and Nasa Ames/Hawaiian Electric/Weinberg Foundation.
Hey a few hours before shipping...
Does anyone know of a way to wire the Double Solenoid
Valve to ONE Spike Relay?
A quick answer would be much appreciated...
Chris
Team #36
#0047 (ChiefDelphi)
Check the Manual...
Posted by Nate Smith at 2/20/2001 5:54 PM EST
Other on team #66, Frostbite, from Willow Run High School and GM Powertrain.
In Reply to: LAST MINUTE Pneumatic Question
Posted by Chris Orimoto on 2/20/2001 5:10 PM EST:
: Hey a few hours before shipping...
: Does anyone know of a way to wire the Double Solenoid
: Valve to ONE Spike Relay?
: A quick answer would be much appreciated...
: Chris
: Team #36
If you look in the manual, it talks about using the diodes(also included in the kit) to write the double solenoid in such a way that you can use a single relay...OR, you could most likely(guessing here now) use the method that's in the manual for connecting two one-way items to a single relay...don't remember exactly where it is, but take a look...
Nate
#0047 (ChiefDelphi)
we tried it with a diode...
Posted by Anton Abaya at 2/21/2001 10:13 AM EST
Coach on team #419, Rambots, from UMass Boston / BC High and NONE AT THE MOMENT! .
In Reply to: Check the Manual...
Posted by Nate Smith on 2/20/2001 5:54 PM EST:
: : Hey a few hours before shipping...
: : Does anyone know of a way to wire the Double Solenoid
: : Valve to ONE Spike Relay?
: : A quick answer would be much appreciated...
: : Chris
: : Team #36
: If you look in the manual, it talks about using the diodes(also included in the kit) to write the double solenoid in such a way that you can use a single relay...OR, you could most likely(guessing here now) use the method that's in the manual for connecting two one-way items to a single relay...don't remember exactly where it is, but take a look...
: Nate
and failed... heh. something went wrong somewhere and we started smelling something funny.
so we just took a spike from last year and used that one. it's the easiest solution.
-anton
#0047 (ChiefDelphi)
Forget The Diodes
Posted by Bill Beatty at 2/21/2001 10:58 AM EST
Other on team #71, Team Hammond, from Team Hammond.
Chris
I recomend that you not use the diodes, but connect one wire from each solenoid to ground and the other wire from each solenoid to a output on the spike. This way the leds will both work on the valve and you don't have to fool with the diodes.
Mr Bill
#0047 (ChiefDelphi)
hmm...
Posted by GregT at 2/21/2001 11:59 AM EST
Student on team #639, RedB^2, from Ithaca High School and Cornell University.
In Reply to: Forget The Diodes
Posted by Bill Beatty on 2/21/2001 10:58 AM EST:
Is that legal?
Greg
: Chris
: I recomend that you not use the diodes, but connect one wire from each solenoid to ground and the other wire from each solenoid to a output on the spike. This way the leds will both work on the valve and you don't have to fool with the diodes.
: Mr Bill
#0047 (ChiefDelphi)
Yep...actually described in the manual (EOM)
Posted by Nate Smith at 2/21/2001 1:05 PM EST
In Reply to: hmm...
Posted by GregT on 2/21/2001 11:59 AM EST:
: Is that legal?
: Greg
: : Chris
: : I recomend that you not use the diodes, but connect one wire from each solenoid to ground and the other wire from each solenoid to a output on the spike. This way the leds will both work on the valve and you don't have to fool with the diodes.
: : Mr Bill
#0047 (ChiefDelphi)
Re: Forget The Diodes
Posted by Gary Bonner at 02/21/2001 10:06 PM EST
Other on team #433, Firebirds, from Mount Saint Joseph Academy and SCT Corp., FMC Corp..
The setup with the diodes has two benefits. One, you can run just two wires from the spike to the valve and still operate both solenoids. Also, the diode setup prevents the possibility of activating both solenoids at the same time, with unpredictable results. However, most likely your valves won't be located far from the spike, so running three or four wires wouldn't be a problem; and activating both solenoids simultaneously can be avoided with careful programming.
Also, if you do connect the valve without the diodes, make sure you connect the correct leads to the relay. This depends on the type of spikes you have. If I recall correctly, you connect the red leads if you are using a blue spike, and the black leads if you are using a red spike.
[IMG] code is Off
my idea of a question forum... Ken Leung General Forum 12 30-11-2002 12:17
MnM EASY Question of the Day Winners! Mike Bonham General Forum 22 03-05-2002 21:21
Chief Delphi Site Question Mike Bonham General Forum 1 16-02-2002 22:18
Yet another time limit question (about exec summary) Caroline Chairman's Award 1 06-02-2002 17:14
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 04-02-2002 00:39
