Go to Post Note that these comments are based on the 2006 FRC game rules, and they may or may not apply to the 2007 game. Your mileage may vary. - dlavery [more]
Unread 24-01-2009, 12:18
Team 1413 Team 1413 is offline
FRC #1413
Team 1413 is an unknown quantity at this point
Panel Signal Device
Where should this be located?
Unread 24-01-2009, 12:41
eitang eitang is offline
Hamosad 1657
AKA: Eitan Galon
FRC #1657 (Hamosad)
eitang has a spectacular aura abouteitang has a spectacular aura about
Re: Panel Signal Device
Here you go:
<R58> ROBOTS shall use the diagnostic Robot Signal Light provided in the Kit Of Parts. It must be
mounted on the ROBOT such that it is easily visible while standing three feet in front of the
ROBOT in the STARTING CONFIGURATION. The Robot Signal Light must be connected
to the “RSL” supply terminals on the Digital Sidecar, which provides power and control for
the light. The team has no direct control over the light and no programming is required.
Unread 25-01-2009, 20:44
Team,
Please make sure the light is securely mounted and inside the robot frame where it will not be torn off during competition. You can find wiring information of the Robot Wiring Diagram on the First Website.
Unread 25-01-2009, 20:48
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
ALSO make sure that it is on the FRONT. Otherwise you show up on the field with a robot facing the wall. And this year you'd really be out of luck with the trailers.
FRONT
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
Diagnostic Signal LED Dung H Cao Electrical 13 08-02-2008 13:24
G<38> Signal To Pass Rule aaeamdar Rules/Strategy 9 07-01-2008 00:07
Signal Light DustinB_3 Electrical 10 21-02-2007 13:10
Robot signal light 11Mort11 Regional Competitions 11 19-02-2007 10:46
Boosting signal on radios? Dave Hurt Technical Discussion 2 14-11-2001 16:07
