Go to Post FRANK, YOU'RE THE MAN. - Libby K [more]
Unread 24-01-2009, 13:26
jnutzmann jnutzmann is offline
Nutzy
FRC #2606
jnutzmann is an unknown quantity at this point
Downloading code DS says "No Code"
We successfully completed all the benchtop testing, updated the Driver's Station firmware with windriver and reimaged the cRIO.
We are attempting to download just the basic code (no modifications), and are running into some issues. First, we download the code, and we noticed that no "completed" or "deployed" message is shown, so we were unsure if it was finished.
We can power it on, get it connected and it will work. But then when we try to download new code the DS displays "Battery: No Code," and the joysticks do nothing.
Jonathan Nutzmann
Team 2606 Mentor
Institute of Technology
University of Minnesota
Undergraduate
Unread 24-01-2009, 13:33
KRibordy KRibordy is offline
FRC #1000 (Cybearcats)
KRibordy is an unknown quantity at this point
Re: Downloading code DS says "No Code"
When we download the code, we download it with WindRiver and then reset the robot. Then, on the DS, it should display "Battery: No Comms" for about ten seconds. Then, for another few seconds, it will display "Battery: No Code". Then it displays "Battery: 0.0V" for us. When that message is up, the joysticks start working.
Unread 24-01-2009, 13:37
Nutzy
FRC #2606
For us it just stays on "No code" and never displays a Battery voltage and the joysticks dont work.
Jonathan Nutzmann
Team 2606 Mentor
Undergraduate
Unread 24-01-2009, 13:52
You are resetting the robot after downloading the code, right?
And you're downloading the .out file to the robot, not the .cpp file, right?
Unread 24-01-2009, 13:54
Nutzy
FRC #2606
Yes we're resetting the robot and downloading the correct file
Jonathan Nutzmann
Team 2606 Mentor
Undergraduate
Unread 24-01-2009, 17:05
C222's Avatar
C222 C222 is offline
Computer Science Major
FRC #0852 (Athenian Robotics Collective)
C222 is on a distinguished road
We've had this problem a few times with our bot. It's usefull to have a serial connection to a terminal on the programming computer. During boot-up, if it says it "unloads" your code, there is probably part of the code the cRio didnt like. Generally, for my team, it was because of an "inline" function.
Unread 24-01-2009, 19:20
Analog's Avatar
Analog Analog is offline
AKA: Bob Most
FRC #2619 (The Charge)
Analog will become famous soon enoughAnalog will become famous soon enough
Is there a document that tells how to use the serial interface, and what information the interface yields?
Unread 24-01-2009, 19:28
Directions are found in the Control System Manual Chapter 5 Configuration in section 5.4.1, cRIO Console Serial Connection to Laptop
Unread 24-01-2009, 20:49
Analog's Avatar
AKA: Bob Most
Thanks. There is also a more detailed account at NI for those following this thread:
http://zone.ni.com/devzone/cda/tut/p/id/6537
Unread 26-01-2009, 15:54
CrashOverride's Avatar
CrashOverride CrashOverride is offline
FRC #1831
CrashOverride is an unknown quantity at this point
One important item that is easily overlooked is that you MUST:
Build your project first, Select the Window menu, Select preferences...,
FIRST Downloader Preferences.
1. Team Number
2. the file to download to the Robot: (This file will have the same name as your project with the extension .out) Browse for this file in the workspace/projectname/(usually Debug) ... directory
Only after you select the correct .out file will your code download. This section does NOT change when you change projects, you must remember to change this setting every time you change to a different project name.
Unread 26-01-2009, 16:08
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
We had a very similar issue before. If the cRio does not like the code, it will display the "No Code" message. Have you updated your WPILIB files yet? There is an update for WindRiver on the FIRST website that will upgrade your library files to the new revision. My understanding is that it might change some of the example projects. If the examples have the wrong code format, it might not be compatible with the cRio updates.
Go here: http://first.wpi.edu/FRC/frcupdates.html and download the workbench updates.
I think that if you can download code your connection and transfer are solid. It just sounds like it's a code problem.
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 27-01-2009, 14:04
Analog's Avatar
AKA: Bob Most
Its not just that it doesn't like the code, or using the wrong file in the download. Use the Rs-232 link to see exactly what the error is. This is most helpful.
Downloading code- DS says "No Code" Bryan Herbst Programming 6 05-01-2009 19:46
"Battery: No Code" after uploading .out file to cRIO knine143 FRC Control System 1 20-12-2008 22:14
Screenshot of "code not understood" or similar error needed! Elgin Clock Programming 3 17-02-2006 22:06
Modified default code gives "code violation" scottmso Programming 8 10-02-2006 23:17
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
