Go to Post All screws are not created equal. - Al Skierkiewicz [more]
Unread 24-01-2009, 13:53
KRibordy KRibordy is offline
FRC #1000 (Cybearcats)
KRibordy is an unknown quantity at this point
Digital Inputs
After a few days of frustration, I figured out what we were doing wrong with digital inputs. The digital inputs aren't "pulled down" so they read unpredictable values. Our button makes the input read "0" when pushed, which is fine, but when it's NOT pushed, the value fluctuates between 0 and 1. Is there any way we can make the "not pushed" value remain at a constant value?
We just have a switch hooked up to the signal and ground wires of a pwm cable.
Do we need resistors or something else?
Unread 24-01-2009, 14:17
Eric Finn's Avatar
Eric Finn Eric Finn is offline
FRC #0166 (Chop Shop)
Eric Finn has a spectacular aura aboutEric Finn has a spectacular aura about
Send a message via AIM to Eric Finn
Re: Digital Inputs
You probably need the +5v wire connected.
It always takes longer than you expect, even when you take into account Hofstadter's Law.
--Hofstadter's Law
Unread 24-01-2009, 14:27
nick fernandes nick fernandes is offline
FRC #0166
nick fernandes is an unknown quantity at this point
Re: Digital Inputs
what kind of switch are you using, and how many positions is it?
Unread 24-01-2009, 18:41
Re: Digital Inputs
We got it working with a single pole, double throw switch with the Signal wire connected to the center, and the Ground and +5V on the outsides. We'd like to use a push button. However, that only has two inputs. So what I was thinking was having the pushbutton connected to Signal and +5V (or signal and Ground) and having a resistor that connects the two inputs, so when the switch is not pressed, the input reads 0, instead of the on/off flip flop it usually does. Someone in another topic suggested using a resistor, but so far I have not been able to get this working.
Unread 24-01-2009, 22:07
Re: Digital Inputs
Your switch should probably be between Signal and Ground, with a 10k resistor between Signal and +5.
You can do it in the other direction, with the switch between Signal and +5 and the resistor between Signal and Ground, if you want.
Unread 25-01-2009, 00:35
Re: Digital Inputs
Ah. I guess that would make sense, wouldn't it?
Thanks. I'll try it out on Monday.
reading multiple digital inputs angelkat Programming 2 25-01-2009 00:22
digital inputs: some bad? Trav-O Electrical 3 18-02-2008 23:29
Digital inputs in autonomous mode? Calvin Programming 8 18-02-2006 13:16
Digital inputs, bandwith, errors? Micah Brodsky Programming 7 20-01-2003 16:08
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
