Go to Post When you are able to get inside their heads, you will either... or.. B) Learn way to much, and end up running away screaming. - Either way, it'll be a learning experience. - Elgin Clock [more]
Unread 17-01-2009, 16:33
cz2062 cz2062 is offline
FRC #2062
cz2062 is an unknown quantity at this point
Chain
I was not able to create a chain on Inventer with the single sized link in the kit of parts.
Was anyone able to do this?
Unread 17-01-2009, 16:49
Ozeaden Ozeaden is offline
FRC #1388 (Eagle Robotics)
Ozeaden is an unknown quantity at this point
Re: Chain
our team was able to. its a witch with a b to get it done, but its possible. there is an actual chain selection, its just hideing.
http://www.eaglerobotics.com/
Unread 18-01-2009, 11:13
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Re: Chain
Inventor has a feature called "Chain Generator"
If you search in the help menu of Inventor you can find instructions on using the tool.
check out this video if you want a quick overview.
http://usa.autodesk.com/adsk/servlet...112&id=9444974
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 24-01-2009, 14:56
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Re: Chain
I searched my schools inventor help and didn't find it
Unread 24-01-2009, 15:07
Bus1012 Bus1012 is offline
FRC #0314
Bus1012 is an unknown quantity at this point
Re: Chain
so theres a help in the program to generate chain instead of making each link
Unread 24-01-2009, 15:10
joek's Avatar
Re: Chain
at least, there should be, but ours doesn't have it
Unread 24-01-2009, 16:16
Srimongka Srimongka is offline
FRC #2410
Srimongka is an unknown quantity at this point
Re: Chain
is it the roller chain generator or is it called something else and can we use the sprockets for the gears instead of the ones that are generated already in the roller chain generator because it keeps creating a new gear for it
Unread 26-01-2009, 12:12
lynca's Avatar
Andrew Lynch
Re: Chain
The roller chain generator default in Inventor has a few quirks.
I suggest using one of thee 3rd party auto chain generator if you are having trouble.
http://www.sdotson.com/viewparts.php...20transmission
(check out the link with rollerchain.zip)
Let me know if you have trouble getting it to work
Unread 28-01-2009, 16:54
pearldrumzach pearldrumzach is offline
FRC #0401
pearldrumzach is an unknown quantity at this point
Re: Chain
Hey guys... Just wondering, can anyone tell me how they constrained a chain using the .ipt files in the KoP for their drawings? I've never done chain before... only belts. I personally don't like the chain generator in Inventor (I mean, the chain looks like a belt...), and was wondering if anyone knew how to go about using .ipt files and making/constraining the chain. I've created a chain with the correct amount of links and everything... I just don't know where to go from there (I tried constraining it and got frustrated when it wouldn't work after a good hour)
Thanks!
-Zach
Unread 29-01-2009, 01:03
lynca's Avatar
Andrew Lynch
Re: Chain
Which model did you use to create the chain (post a link to the model)?
If you made your own custom model chain ipt file, please post the file so others can understand how to help.
Unread 29-01-2009, 09:35
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Re: Chain
In an ipt file create a sketch for the path of the chain (actually I think the DAcc already does this for you).
In the ipt with the path create a workpoint on the path.
Use the Rectangular Pattern command (should be called Curve Driven
Pattern - where often the "curve" is a straight line) to pattern the workpoint but the center-to-center distance of the chain link (pitch).
In the assembly constrain one link to the first two workpoints on the path.
In the assembly use Pattern Component and use the "Rectangular Pattern" feature of the Workpoints to pattern the rest of the chain links.
http://www.chiefdelphi.com/forums/at...9&d=1200330921
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 30-01-2009, 13:11
FRC #0401
Re: Chain
I used the chain .ipt files in the Kit of Parts files downloaded from FIRSTbase.
JD - I created a chain, with the correct number of links. I am just unsure how to go about constraining it within the whole assembly of the robot. Is there any way I can make the chain "work" (I don't know the real word for it, but by "work" I mean can I constrain it in any way to where the chain will turn when the sprocket turns in the assembly)?
Thanks for the help, guys.
Unread 31-01-2009, 01:09
Team1710's Avatar
Team1710 Team1710 is offline
FRC #1710
Team1710 is an unknown quantity at this point
Re: Chain
Just wondering if there is a way to replace the beltish look of the chain generator. Honestly it doesn't look like chain at all. Plus our team uses ANSI 35 chain and the generator only has ANSI 40 for the smallest chain. Does anyone know how we could use ANSI 35 in the generator?
Unread 31-01-2009, 20:18
Team1710's Avatar
FRC #1710
Re: Chain
Sorry but I need to bump this. The over all look of the chain generator is very cheesey. Plus the smallest version of chain in the generator is ANSI 40 but our team uses ANSI 35. Has anyone found a way to make the chain look better and/or used ANSI 35 in the generator?
Unread 01-02-2009, 11:21
lynca's Avatar
Andrew Lynch
Re: Chain
I suggest using one of the 3rd party auto chain generator if you are having trouble.
Above is another option that looks better as a chain than the Roller Chain Generator.
Chain hong12891 Inventor 8 05-02-2007 20:03
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
25 or 35 chain? Alan Ing Technical Discussion 24 02-03-2003 13:56
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
chain Lake Orion OCCRA 1 30-09-2001 13:20
