Go to Post I know my posts are sometimes exhausting but there are PICTURES in this one, if that helps at all. - Jaine Perotti [more]
Unread 24-01-2009, 15:35
potnisanish potnisanish is offline
FRC #2410
potnisanish is an unknown quantity at this point
Camera Framerate Problems
Our camera can display images through the computer, and track colors as they move. But we only get about 10 fps, and I believe the camera is supposed to display 30 fps.
Does anybody have any ideas on how to increase the frame rate?
Unread 24-01-2009, 21:02
Re: Camera Framerate Problems
Decrease the resolution. You might find you get useful images at 160x100.
Unread 25-01-2009, 11:28
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
You might even find you get good images at 160x100 decimated 2 by 2.
Unread 25-01-2009, 14:10
deusex's Avatar
deusex deusex is offline
FRC #0422
deusex is an unknown quantity at this point
yeah, i went to a seminar on the stuff at kickoff and some team that betatested said that they were unable to get about 7-8 using wifi
anyways, you really can't even use the camer to get direct to station during the competition
As Witicha Falls....
So Falls Witicha Falls
Unread 25-01-2009, 14:59
360skier 360skier is offline
RTFM!!
AKA: Eric A.
FRC #1334 (Red Devils)
360skier is an unknown quantity at this point
Apparently turning off the camera at the dashboard increases the framerate substantially. Other than that, size seems to be the most important factor.
Unread 26-01-2009, 12:25
drkiraco drkiraco is offline
FRC #1747
drkiraco will become famous soon enoughdrkiraco will become famous soon enough
In general, when you are looking for bottlenecks in code, the tool you want to use is called a "profiler". it tells you which parts of your code are using the most memory and cpu. in labview it's under block diagram->tools->profile->performance and memory. once you've identified which parts are causing the slowdown, then you may be able to think of clever ways to re-code that part to be faster.
Unread 26-01-2009, 15:25
Jared Russell's Avatar
Taking a year (mostly) off
Turn off the dashboard, and reduce the image resolution.
Camera Problems!!! spsteam1512 Programming 0 12-02-2007 13:45
Camera Problems CMB Programming 2 02-02-2007 18:24
Camera Problems 804_twidget1 Electrical 4 27-01-2007 11:28
Camera Problems pickle Programming 21 20-01-2005 20:43
Framerate? Undefined One 3D Animation and Competition 9 16-03-2002 18:21
