Go to Post Making GP a rule would be the equivalent of making a law that says you have to help get kittens out of trees. - Molten [more]
Unread 01-23-2009, 08:39 PM
agough's Avatar
agough agough is offline
FRC #0234 (Cyber Blue)
agough is an unknown quantity at this point
Exclamation Catastrophic error
I am testing sending outputs from c++ to dashboard(if you could help with that also I would appreciate it.) When I #include "WPILib.h" it says it cannot open target file "WPILib.h". the odd thing is that this has not happened before and we have other code(not involved with these) that uses it successfully. Could you please either tell me where it needs to be to successfully reference it or what has gone wrong in the code(I am pretty sure that it is something obvious and I am not seeing it).
File Type: h Dashboard.h (134 Bytes, 54 views)
Unread 01-24-2009, 08:10 AM
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Catastrophic error
Did you move the contents of C:\WR around? that might have an effect, if you did not, do File>new>example, the middle choice, FRC simple template (or something of that sort), and try that, you might have messed up your project includes.
Watchdog.Kill();
Unread 01-24-2009, 09:30 AM
agough's Avatar
Thank you for the help, It solved the error. But could you confirm that there is a dashboard type. i am useing the c++ code from team 67 and I don't know if they created it themselves or they used it from somewhere.
"By failing to prepare, you are preparing to fail."-Benjamin Franklin
"Wise men talk because they have something to say; fools, because they have to say something."-Plato
Unread 01-24-2009, 03:36 PM
agough's Avatar
I found the dashboard type(had to download the updates).
LebView Error -- Error 1055 occured at Property Node in FRC Create Project.vi->FRC Wi RMS11 Programming 8 12-08-2008 06:20 PM
Error in code light on, trouble finding error Bryan Herbst Programming 16 10-12-2007 09:59 PM
180:Error: syntax error help! seanl Programming 8 02-04-2007 11:31 AM
stupid Array error: Error [1300] stack frame too l Validius Programming 7 01-27-2006 10:53 AM
