Go to Post ...it takes a very special kind of person to equate bagpipes with harps. - Kevin Sevcik [more]
Unread 24-01-2009, 11:27
TeenDev TeenDev is offline
Lead C++ Programmer
AKA: Max Fierke
FRC #2823 (Flowbotz)
TeenDev is an unknown quantity at this point
Send a message via AIM to TeenDev Send a message via MSN to TeenDev
Bumper Height
Hey everyone,
How high do the bumpers have to be from the ground? We looked thrugh the rule book, asked our rulesmaster, but we couldn't find the answer.
Unread 24-01-2009, 11:43
Re: Bumper Height
From 8.2 Definitions in Section 8
BUMPER ZONE – the volume contained between two virtual horizontal planes, one inch above the floor and seven inches above the floor.
The bumpers must be mounted to satisify this definition.
Unread 24-01-2009, 12:21
waterfreak#1's Avatar
waterfreak#1 waterfreak#1 is offline
nate
AKA: 6
FRC #1388 (eagle robotics 1388)
waterfreak#1 is an unknown quantity at this point
Send a message via Yahoo to waterfreak#1
Re: Bumper Height
in our rule book we founf it said that it had to be 1 3/16 inches off the ground
the passage below is false
the passage above is true
Unread 24-01-2009, 13:34
Re: Bumper Height
Nope, that's the trailer hitch, at (2 3/16)" from the ground to the horizontal centerline. Al is correct.
Unread 24-01-2009, 13:43
The phenom's Avatar
The phenom The phenom is offline
FRC #1569
The phenom can only hope to improve
Re: Bumper Height
gets hammered?
Unread 24-01-2009, 15:42
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
Re: Bumper Height
Nope, that's the trailer hitch, at 2 3/16" from the ground to the horizontal centerline. Al is correct.
That should be two and thirteen sixteenths inches from the floor (2 13/16).
Unread 27-01-2009, 20:56
MetalGear_Solid's Avatar
MetalGear_Solid MetalGear_Solid is offline
FRC #3007 (Robotitans)
Team Role: Student
MetalGear_Solid is an unknown quantity at this point
Re: Bumper Height
yes...the nail that sticks out does indeed get hammered....
lol
thanks for postin this up...
it took me an hour to find it and i learned something.... hahaha
i have to make the bumper case for our metal gear titan ...
so thanks a bunch..
Unread 29-01-2009, 20:47
ISGOI Howie ISGOI Howie is offline
FRC #2996
ISGOI Howie is an unknown quantity at this point
Re: Bumper Height
sooooo...... the bumpers have to be at least 1" above the ground and 7" at max?
Unread 29-01-2009, 21:20
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Re: Bumper Height
The bumper zone starts at 1" elevation and stops at 7" elevations.
7" minus 1" = 6"
so center the nominal 5" tall bumper between the 1 and 7 " mark
Read under Robot Rules - Definitions - Bumper Zone
Then read <R08>
Ed Barker
Unread 29-01-2009, 22:40
Electrical Engineer
Rookie Year: 1995
Re: Bumper Height
In my humble opinion, you are correct.
Mike Betts
As easy as 355/113...
Unread 29-01-2009, 22:45
Electrical Engineer
Rookie Year: 1995
Re: Bumper Height
7" minus 1" = 6"
Then read <R08>
Ed,
I do not believe that your interpretation is correct. A 6" latitude of placement for a 5" bumper means that the bumpers of two colliding robots could miss each other. This would negate the purpose of the bumper.
If your team's robot design requires a 6" latitude, you should post to the FIRST forum for an official ruling.
JMHO
Mike
Mike Betts
Unread 30-01-2009, 07:18
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Bumper Height
Once again we have a misunderstanding of the words used in the Manual. First we have the definition:
Originally Posted by Manual 8.2
BUMPERS – Bumper assemblies designed to attach to the exterior of the ROBOT within the BUMPER ZONE, and constructed as specified in Rule <R08>. BUMPERS are excluded from the weight and volume calculations specified in Rule <R11>.
And then this:
Originally Posted by <R08>
P. BUMPERS must be mounted to the ROBOT within the BUMPER ZONE, and must remain there. The BUMPERS must not be articulated or designed to move outside of the BUMPER ZONE.
(emphasis mine in all cases)
While the first bolded parts could be read as requiring only the mounting point to be inside the bumper zone, the underlined bold parts specifically say the bumpers themselves must always remain inside the bumper zone. So with a 5" wide bumper, you've got an inch of slop to make sure it stays between 1 and 7 inches from the floor.
(since 2004)
Unread 06-02-2009, 15:11
bighead1358's Avatar
bighead1358 bighead1358 is offline
AKA: Ryan Mancini
FRC #1358 (Generals)
bighead1358 will become famous soon enough
Send a message via AIM to bighead1358
Re: Bumper Height
this whole thread has been both very helpful and confusing im going with higher than one inch and lower than seven? i hope
**WE NEED MORE ZIPTIES**
Unread 06-02-2009, 15:18
Re: Bumper Height
The definition of BUMPER ZONE: "the volume contained between two virtual horizontal planes, one inch above the floor and seven inches above the floor."
<R08-P>: "BUMPERS must be mounted to the ROBOT within the BUMPER ZONE, and must remain there. The BUMPERS must not be articulated or designed to move outside of the BUMPER ZONE."
You are correct in your interpretation.
Unread 06-02-2009, 15:23
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Bumper Height
Yes. But keep in mind, a BUMPER must be made up from 2 pool noodles stacked on top of each other in which each pool noodle is about ~2.5" tall themselves.
This is where the talk about the 5" tall bumper comes into play.
(~2.5" pool nodle + ~2.5" pool noodle = ~5" tall bumper.)
In my crude picture, let the O's represent a pool noodle cross-section & the solid lines lines above & below the O's equal the 5" spacing between the top & bottom of the constructed BUMPER (height of 2 pool noodles). The dotted line represent your horizontal planes of the BUMPER ZONE limits.
------7" (max) from floor
_____
O
O___
------ <-1" (min) from floor
______ <- Floor
Hope that clears up any confusion, & doesn't add any more confusion to your understanding of this!
Bumper Height Zultraranger Rules/Strategy 3 20-01-2009 23:57
Bumper Height? EricVicenti Rules/Strategy 9 14-01-2009 12:23
No height choice? Molten General Forum 12 18-01-2008 15:55
Bar Height Paul H Rules/Strategy 3 10-01-2004 19:28
Ramp Height?!?!?!?!?! archiver 2001 4 24-06-2002 01:41
