Go to Post it would be a sign you do too much robotics when you find toolpaths sexy. - Aren_Hill [more]
Unread 24-01-2009, 15:53
RyanJK's Avatar
RyanJK RyanJK is offline
Does it come in chrome?
AKA: Ryan Kamphuis
FTC #3758 (Juarez Aztec Eagles)
RyanJK is on a distinguished road
Programming the Jaguars
Hey everybody,
We just finished making our custom gearboxes and mounts for the propellors that will drive our robot. We have the Jaguars hooked up, and the props connected to those. All of the electrical is right, and we have a PWM connecting the Jaguar to PWM 1 on the Sidecar attached to Input 4 on the cRIO. We have programmed a program, and deployed it on the robot. When we set the throttle to max, the Jaguar activates (the LED turns solid green), and the fan begins turning at 2 RPM. Any ideas as to why the prop isn't moving at the speed we want it to?
Ryan Kamphuis
Head Mentor, FTC 3758
FRC Game Announcer
Member of the Midwest Regional Planning Committee
2012 - 2015 Chicago, IL Kickoff Coordinator
Alum of FRC Team 2526! Go Crimson Robotics!
Unread 24-01-2009, 18:41
Re: Programming the Jaguars
That would probably be a mechanical issue not a programming issue.
The battery could be weak, but if the Jaguar is showing green, programming is giving it's all.
Jaguars...is this ok? jngleofinsanity Electrical 15 09-02-2010 21:12
Advantages of the Jaguars? EricVicenti Electrical 36 03-03-2009 20:16
Connecting to cRio, getting the jaguars to go solid yellow.... then nothing. DSST\neal.ian FRC Control System 11 30-01-2009 18:15
Jaguars working with 2.4 Ghz R/C NOV8R Technical Discussion 0 09-01-2009 16:15
