Go to Post Sometimes you have to eat your vegetables, do your homework, and get some sleep. Otherwise you may get sick, have bad grades, and or fall asleep during the championship. - IKE [more]
Unread 24-01-2009, 14:44
xxMORT11xx's Avatar
xxMORT11xx xxMORT11xx is offline
FRC #0011
xxMORT11xx will become famous soon enough
Field Connections?
What are all the conections necessary from operators interface to the field?
We checked the manual and we were only able to find power and ethernet ports needed to be available does anyone know what else we need such as competition ports?
Thanks for any help.
Unread 24-01-2009, 15:53
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Re: Field Connections?
those are the only ones needed, except for the dongle, if you use a laptop for programming, you can upload the programing via wireless Ethernet using the wireless router on the robot (it shows up as a wireless internet connection), I don't know what you need for a desktop, my team uses a laptop for programing.
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 24-01-2009, 16:03
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
I'm nearly 100% certain that you'll only need to attach 2 cables to your DS when you place your console on the field's shelf - 1 Ethernet cable and the Competition Port (which also supplies power to the DS). Leave your dongle, power supply and DS-side router in the pits.
Russ
Unread 24-01-2009, 17:03
pitzoid's Avatar
pitzoid pitzoid is offline
AKA: BOB
no team (4FX Design)
pitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of light
Russ is correct
Each Driver Station has a dedicated Team VLAN connection to their robot (ethernet RJ45) and a DB9 that connects to the DS competition port which provides the E-stop loop and 24 volt power for the Team's Driver Station. Just the two connections.
BotBash BOB Pitzer
4FX Design
Unread 24-01-2009, 21:51
Thanks guys. We just wanted to make sure.
Connections to Driver Station Zellboy Electrical 1 23-01-2009 16:24
Self-fabricated electrical connections Shu Song Electrical 6 08-02-2005 08:04
Connections For Camera Eupher Programming 3 02-02-2005 14:35
Frame connections manleycor Technical Discussion 15 18-11-2003 01:14
Drill Motor Connections archiver 2001 8 24-06-2002 00:49
