Go to Post Throughout the "FIRST" experience we're all taught that if we try hard we'll achieve some level of success down the road; it hits everyone differently. - nlknauss [more]
Unread 24-01-2009, 19:09
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Drivers Station Magical Current
Originally Posted by 3DWolf View Post
How could this happen? There's no current or signal flowing from ANYWHERE. My team and I are stumped.
The Driver Station design does not include any pull-up or pull-down resistors on the digital inputs. What this means is that with nothing connected, the input to the DS is "floating" meaning it could read either on or off. In your case, it is reading off, but then when you connect your PWM wire to it, the wire is probably acting like an antenna and picking up some kind of signal (it doesn't take much) and triggering the DS input. What you need to do is make sure that you have a switch that switches between positive and ground, not just a simple make/break switch. What kind of switch were you using?
Telling the drivers station your alliance Mike Mahar Technical Discussion 2 17-01-2009 12:24
Telling drivers station your alliance Mike Mahar FRC Control System 5 17-01-2009 08:43
How Dean Kamen's Magical Water Machine Could Save the World--from Esquire Magazine I_Robot Dean Kamen's Inventions 5 25-11-2008 18:19
The Magical IR Board Uberbots Electrical 6 06-03-2008 07:35
pic: They're Magical! Ianworld Extra Discussion 2 30-01-2005 17:24
