Go to Post Welcome to a Chief Delphi poll, where the responses are made up and the numbers don't matter. - JohnSchneider [more]
  #31   Spotlight this post!
Unread 24-01-2009, 22:55
sbrumund sbrumund is offline
FRC #2115 (M cubed)
sbrumund is an unknown quantity at this point
Re: Team 1646 Shooter Prototypes Video
We are considering driving the ball throwing wheels directly of the 2 1/2 CMI Motor and controlling the motor speeds.
We have not been able to locate a coupler to go from the 8mm motor shaft to the .5" shaft in the wheels or a motor busing to do the same
In a high torque appication like this a key way would be necessary making this a difficult part to make or purchase.
Anyone know where we can purchase this strange bushing?
  #32   Spotlight this post!
Unread 25-01-2009, 01:17
shawn1231 shawn1231 is offline
FRC #1997
shawn1231 will become famous soon enough
We encountered the same problem. We ended up using a Poly-Cord belt for to drive our shooter. We found pulleys at the hardware store but they only came in 1/2" and up. So we started looking around and found a shaft collar/bushing that is about 1 1/2" long and has two large set screws. It just so happens that this 5/16" collar fit the 8mm shaft and that it was exactly 5/8" in diameter. So we bought a pulley to fit the 5/8" bushing.
I don't know about a keyway though. We were able to do it without one simply because our pulley had a gigantic set screw and our bushing has two. If you find that a keyway is not necessary though, definitely try poking around the hardware store just to see what you can stumble across.
Team 637 shooter video X-Istence Robot Showcase 0 23-02-2006 07:43
pic: Team 1523 Shooter + Video Tim Arnold Robot Showcase 40 19-02-2006 10:21
Team 932 shooter video Charger_07 Robot Showcase 2 14-02-2006 22:29
VIDEO: Team 125 Shooter, incident??? Brandon Holley Robot Showcase 11 12-02-2006 00:11
Team 293 Video of Shooter Spikey Robot Showcase 7 11-02-2006 14:12
