Go to Post You have to admit, Regionals are pretty strange places, albiet cool - Otaku [more]
Unread 21-01-2009, 18:02
DuzieInuKenshin DuzieInuKenshin is offline
FRC #2705
DuzieInuKenshin is an unknown quantity at this point
Cannon Design!!!!!! >_<;
So we're trying to build a cannon to shoot the moon rocks at the trailer, but we're having difficulty getting the ball up to speed for any sort of range.
So far we've tried using two spinning wheels in parallel with the ball being moved between them. Help!?!
-Team 2705
Unread 21-01-2009, 18:11
popnbrown's Avatar
popnbrown popnbrown is offline
FIRST 5125 HOTH Lead Mentor
AKA: Sravan S
FRC #5125 (Hawks on the Horizon)
popnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond repute
Re: Cannon Design!!!!!! >_<;
Can you provide us with a picture?
If you have wheels that spin against a ball, it should launch the ball. Unless it there's too much friction between the spinning wheels and the balls that the ball gets stuck on the wheels and starts spinning.
Depending on the type of wheel you are using the cloth of the ball might be getting stuck.
It would actually also help if you could put up a video of the system working.
From team history, we used a pretty big wheel maybe 8in in diameter to launch a squishy but completely solid ball (unfortunately, I don't know what type of the top of my head) in the 2006 game Aim High.
Your best option is probably to search chiefdelphi and thebluealliance.net to look for other shooter designs from the 2006 game.
If there are any other things that I can help you with PM me. I'll ask my team members who were involved with the 2006 robot, to give you some specifics if you would like.
Good Luck,
Sravan
I am an employee of FIRST. However, the postings on this site are of my own perspective as a FIRST mentor and volunteer and do not necessarily reflect the views of FIRST.
FIRST Team 5125 Hawks on the Horizon Lead Mentor
FRC Team 4096 Ctrl-Z Former Mentor
FTC Team 5203 #19@! Former Mentor
FRC Team 1403 Cougar Robotics Alumni
Unread 21-01-2009, 18:18
Are you starting the ball directly between the wheels? If you are, you shouldn't be. Give it a little speed coming in.
Also, what motors are you using? Some motors (say, the window motors) are not good for this type of system.
Oh, and popnbrown--the infamous Poof balls (shelled) were the victims in 2006. If you raided your local Walmart in the hunt for the Orbit balls, you may have seen the unskinned version.
Unread 21-01-2009, 18:26
FRC #2705
We don't have a video camera/regular camera... whoops....
So far, we're just prototyping some shooter designs in order to shoot the ball vertically into a chute. The design we have so far is using 2 rubber wheels with a diameter of about 6 and a a wheel tread of about 1 in, so they're kind of small. We think the problem is that there is too little contact area between the moonrock and the wheel, but don't know how to fix that when the moon rocks themselves are full of holes. The only solution we have so far is to use 4 wheels and put belts between them to increase contact. We're just starting the ball at a dead start. Similarly, we arent using any motors so far, we just have some wheels attached to some drills, so we're not sure how accurate of a representation this is. Sorry if this isnt very descriptive. >_>
Unread 21-01-2009, 18:40
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
It is possible that the wheel is not wide enough to power the moon rocks well, but there are a number of other possibilities.
As Eric mentioned, this type of mechanism works the best when the wheels are already spinning and then the ball is fed into them.
Another potential issue is compression. Based on what teams have been reporting here and what my team has seen in very limited testing you want at least an 1" of compression at the narrowest point between the two wheels meaning they should be 8" apart at the most. You also don't want more than about 2" of compression so they should be at least 7" apart.
The last potential issue results from the drills. If the drills are not providing enough speed or torque or both your design may not work well. If the wheels are not spinning fast enough they will not transfer enough energy to the ball as it passes through. If the drills don't have enough torque, the wheels will slow down too much as the ball passes through and the wheels will then not transfer enough energy to the ball.
Unread 21-01-2009, 18:42
Originally Posted by DuzieInuKenshin View Post
So far, we're just prototyping some shooter designs in order to shoot the ball vertically into a chute. The design we have so far is using 2 rubber wheels with a diameter of about 6 and a a wheel tread of about 1 in, so they're kind of small. We think the problem is that there is too little contact area between the moonrock and the wheel, but don't know how to fix that when the moon rocks themselves are full of holes. The only solution we have so far is to use 4 wheels and put belts between them to increase contact. Sorry if this isnt very descriptive. >_>
Wheels are a decent diameter, and using more wheels may help.
Though--let's look at this closely. You're shooting vertically into a chute. Straight up or straight down? If it's straight up, you might want to look into a belt system.
Unread 21-01-2009, 20:40
FRC #2705
We'll try out more wheels tonight and tomorrow.
It would shoot vertically into a curved chute. The chute would be on a lazy-suzan type turret - with a wide enough center hole for the balls to pass through unhindered- which could turn to aim in different directions.
Unread 21-01-2009, 21:42
You may want a belt system, but if you need to go with a launcher, you want to be able to go horizontally after the vertical launch.
Let's say you need to go 3 ft. horizontally from the top of the robot. You need enough speed to go that far left over from the upwards launch.
Let's start with the horizontal portion. Launching at 4 feet, you need to clear 3 feet. So you can't go more than 1 foot downwards, and you need to go 3 feet horizontally, reliably. You'll have an upwards trajectory from the launch, but we'll ignore that for now. We need to go horizontally and vertically, so for vertical motion, s(t) = -1/2g*t^2 + v*t + hi, where g is gravity, hi is initial height, and v is the initial velocity. hi is 4 ft and v starts at zero. s(t) ends up at -1. So... -1 = -1/2*32*t^2 + 0 + 4, -5 = -16*t^2, 5/16 = t^2, t = 0.559 seconds.
Now, how fast does the ball need to go to go 3 feet in that time?
s(t) = v * t for horizontal motion. s(t) needs to end up being 3 ft, and we have t from above = 0.559 s.
3 = v*.559, v = 3/.559, v = 5.3 f/s coming off the top of the chute.
So, if it has to go 5.3f/s coming out, and it has to climb 3 feet, let's look at that equation for vertical motion again. s(t) = -1/2g*t^2 + v*t +hi. We'll assume you want to lift the ball 4 ft.
But we're interested in v(t), so we take the derivative of s(t). v(t) = -g*t+v.
5.3 = -32*t+v; t = (5.3 - v)/-32.
Substitute into the s(t) and you get 4 =-1/2*32*((5.3-v)/-32)^2 + v(5.3-v)/-32 + 1; 3 = -16(28.09 -10.6v+v^2)/1024 -0.165v+(v^2)/32
3 = -0.438 + 0.165v +.0156v^2 - .0165v + 0.0313v^2
3.438 = 0.0469v^2
v = 8.56 f/s launch speed minimum. 10 f/s would be better to start the balls at.
I'm sure that you can run the numbers to figure out what speed the wheels need to spin to impart that speed; wider wheels may help as well to avoid digging into the holes in the ball.
Unread 22-01-2009, 09:02
James Slemons James Slemons is offline
FRC #0027 (RUSH)
James Slemons is an unknown quantity at this point
I too think that is your problem there.
Back in 2006 we were prototyping shooters and ran into the same problem. The balls just spat out instead of shooting them and after moving the wheels closer together they went flying.
Unread 22-01-2009, 09:21
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Noncompression solution
Paddle wheel is my solution, instead of compressing the ball it pushes it from behind, and since it's a circle it can reload faster then a pneumatic ram.
With wheels on the side you need at least 2, one for each side, if your using belts you can get away with one since the ball will be in contact for a longer time. The main issue with the wheels is friction (again!), compressing the balls increases the force of friction (which your going to want maxed out), so you might want to rap the wheels in hocky tape or velcro to increase friction between ball and wheel
Is now an engineer thanks to FIRST.
Unread 22-01-2009, 11:45
Re: Noncompression solution
No, you don't. 1 will do just fine, if you have a back plate to compress against. 2006 showed that. Contact time has little or nothing to do with it.
I was thinking a bit (dangerous, I know), and had a thought: What if most of the chute didn't rotate, but just the top part did and had the launching wheels close to it? You could run a belt up to the top and have a slower launch speed because you no longer have to fight gravity for the full distance. You also have the ball moving when it comes in, so there is less motor speed loss, and you can shoot faster.
Unread 23-01-2009, 16:07
ZakuAce's Avatar
ZakuAce ZakuAce is offline
AKA: Garrett
FRC #2077 (Laser Robotics (Alumni))
ZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of light
This sounds a lot like what we're planning on doing. We used the 8" andymark traction wheels to shoot it up, with what I'm thinking is about 1 inch or so of compression. We're driving it with a 32 teeth drive sprocket and the sprockets on the wheels are whatever they come standard with. The gearbox is a banebots 4:1 planetary. I'm are trying to get a bigger (more teeth) drive sprocket, but I haven't found anything yet. I don't even know where we got these 32 tooth ones. We haven't tried shooting them up a chute yet, as we don't have material yet to prototype that. We got to shoot it vertically about 8 feet or so. Seems to be fairly consistent. Hopefully we can find something to prototype the chute with Saturday, because I'm worried about being able to actually get the ball out of the chute. I don't think we have quite enough power yet behind the launcher.
BTW, we also direct drove them from the cim motors. Don't do that. The speed is ridiculous, and it could probably throw the orbit ball a long way, but I bet the ball would get destroyed in the process. It already looks pretty battered.
I was thinking about this as well, but mounting the motors and getting it all situated seems like it would be somewhat more complicated. If you just use the chute to direct the orbit balls, it can be extremely light, make of thin aluminum that could save you a decent amount of weight compared to mounting it on top of the chute, which would have to be made out of much stronger material.
Unread 24-01-2009, 22:33
Kraftyman Kraftyman is offline
FRC #0847 (PHRED)
Kraftyman is an unknown quantity at this point
Greetings,
Try using 4 of the previous years traction wheels. Two by two really keeps the ball cruising and helps pick them up out of whatever hopper you have to store these things. I agree that the CIMs should not be used directly, as we had some trouble today. A geared or belt system running both sets of wheels will keep them spinning at the same speed and at reasonable speed. Direct drive with the CIM motors could clear 15 feet in our test, but that just bounces of the center post in the trailer. Good luck!!
KraftyMan
newbie mentor for Nypro Oregon
Unread 24-01-2009, 23:05
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
One problem you can encounter is if you try to fire the ball from a stopped position, but if you give it some speed before the ball meets the rollers it should work a lot better. For instance a gravity driven shoot to the rollers or a start-up roller/wheel.
Unread 24-01-2009, 23:12
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
From a Physics standpoint I'm not sure that argument holds water. With all things being equal, the amount of time that I apply a given force will directly affect the velocity of an object. The more time I have to apply the force the faster the object will travel. For example: compare the muzzle velocities of a pistol vs. that of a rifle.
potato cannon northendchopper Chit-Chat 14 16-12-2009 12:19
Air Cannon Rob2713g General Forum 40 27-05-2009 21:15
ball cannon??? stinkypooman General Forum 142 06-03-2009 13:48
air cannon Evil Asian General Forum 10 15-03-2007 10:31
Air Cannon Michael223 Technical Discussion 13 14-06-2006 10:23
