Go to Post Ahh yes, the good old "let's dedicate all our resources to absolutely cheesing the opponent alliance" strategy - Jaci [more]
Unread 25-01-2009, 00:08
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
gyro counting up
This is something that we've been having trouble with--when we plug the gyro into an analog input, and call getAngle, we get no meaningful signal, but instead basically a number that keeps counting up. The number isn't altered by actually moving the gyro about its axis, which means it isn't drift.
Does anyone have any ideas on what could cause this, or how to fix it? It should be noted that we are using a 2008 gyro due to our new one frying
Get yer robot source code here!
Unread 25-01-2009, 03:38
Re: gyro counting up
Perhaps you've connected to the Temperature output of the YRS instead of the Rate output. They were badly labeled last year, with "R" for "relative temperature" and "T" for "twist".
Or perhaps that one too is fried. What happened to your 2009 sensor?
But I have to point out that the Yaw Rate Sensor/Gyro from the 2008 Kit of Parts was a custom part that year, is not (and never was) commercially available, and is thus not a legal part for this year's robot.
Unread 25-01-2009, 11:19
elstaqub elstaqub is offline
Purported Programming Mentor
AKA: Ed Staub
FRC #0131 (C.H.A.O.S.)
elstaqub is an unknown quantity at this point
See http://forums.usfirst.org/showthread...5204#post25204.
Yes, some of them are mis-wired.
Encoder Counting Problems RyanW Programming 1 14-02-2007 15:17
12 Hours and Counting Jherbie53 Championship Event 0 27-04-2006 20:33
GTS Counting gnirts Programming 13 21-04-2006 21:15
counting digital input CharlieWilken Programming 9 22-03-2004 19:56
PUlse counting junkyarddawg Technical Discussion 1 31-01-2002 15:33
