Go to Post Imagine a world solely consisting of FIRST students. Oh the things that we could do. - Ryan Himmelblau [more]
Unread 24-01-2009, 17:08
Slick Slick is offline
Slick is an unknown quantity at this point
Camera error message
We are using the advanced Labview program and started working with the camera today. We downloaded the new version of the FRC Labview code last week. We also downloaded the new version of the Labview camera code from NI. This is the error message we received today. Need some guidance on this one. Thanks for any help.....
Error -44085 occurred at FPGA Bit File has incorrect version or revision.
This error code is undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code input.
Unread 25-01-2009, 11:34
Re: Camera error message
The first part of the message about the bitfile being the wrong version is the explanation.
My guess is that you need to run the cRIO imaging tool. Be sure to check the format checkbox and choose the latest file (biggest version number). It will take fifteen minutes or so to run. At the end of this, your bitfile on the cRIO will match the WPI library functions you are using.
Greg McKaskle
message too short error Melissa Nute CD Forum Support 7 03-06-2004 00:02
Error message in MPLAB IDE dddriveman Programming 11 18-03-2004 06:34
hexidecimal error message in notepad Anthony Kesich Programming 6 09-02-2004 18:42
Header File error message Mike Yan Programming 2 09-02-2004 11:31
Error Message Obi Programming 4 24-01-2004 20:10
