Go to Post I love losing my voice in the name of F.I.R.S.T :) - Athleticgirl389 [more]
Unread 25-01-2009, 15:52
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Limit Switch return value
There are two jumpers there when you first get it, those are the limit switches. When the connection between the two pins is broken the motor stops turning in that direction. Under each of those sets of 2 pins a letter either F or R for forward and reverse. Just hook a two pin cable into one of those and hook that to a limit switch in the normally closed position and instant limit switch, no programming required
Also if you have jaguars that you don't want to use this feature for (I.E. drive motors) make sure you tape the jumpers in so they cant fall out during competition.
For next year keep an eye out for allowed features with the other connectors
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
limit switch wedellm Electrical 4 16-02-2007 13:01
No value in digital ins using NASON pressure switch. Ari Allyn-Feuer Programming 1 18-02-2006 01:18
Limit switch in easy c? chadbarbe Programming 6 02-02-2006 09:51
