Go to Post The low bar will make your electronics team cry. - Joe G. [more]
Unread 25-01-2009, 17:10
Bus1012 Bus1012 is offline
FRC #0314
Bus1012 is an unknown quantity at this point
Re: JPEG Images for Inventor
Hows everyone's inventor projects coming
Unread 27-01-2009, 15:56
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Issues with constraining extruded aluminum
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 29-01-2009, 09:38
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
In addition to the Save Copy As type *.jpg method
there is also the Applications>Inventor Studio method that will give you a higher quality Rendering.
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 29-01-2009, 19:13
FRC #0314
Thank you all for the help in saving my Inventor project as a .jpg image
Unread 29-01-2009, 21:13
5n1p3r's Avatar
5n1p3r 5n1p3r is offline
IM 5n1p3r
AKA: Matthew
FRC #0714 (Team Panthera)
5n1p3r will become famous soon enough5n1p3r will become famous soon enough
Send a message via AIM to 5n1p3r
Arrow Re: JPEG Images for Inventor
Im actually doing pretty well on my inventor project, my frames awesome, cant wait to throw it out on the simulation track
Unread 29-01-2009, 21:48
Dan Richardson's Avatar
Happy Birthday! Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
I'm not familiar with the profile your trying to constrain but it may be easiest to create a reference plane along the face that you are trying to constrain it to. Depending whether or not your trying to create dynamic constraints. When I first started I never had considered using reference plains for constraints but it works well enough on strange shapes.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 29-01-2009, 22:15
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
If you're trying to constrain accurate 8020 profiles there is only a tiny flat section on the surface. If you are using flush constraints this is the only surface that will work as expected.
You often have to zoom in quite a bit for the flat strip to show up. Once you learn how to do this it will become second nature.
Also beware that the extrusions are 7 mil smaller their nominal length. You might have to use an offset to account for this.
80/20 has a 4 degree angle to make a vibration free connection. There is nothing stopping you from modifying the profile to be more square and easier to work with for your model.
Inventor images from Industry pmax Inventor 0 08-01-2007 19:20
Inventor Images help Dylan Gramlich Inventor 6 25-12-2006 23:05
pic: ParagonUTCteam.jpeg Steve Howland Extra Discussion 1 13-03-2006 21:58
Images for 2006 boy_scout72688 General Forum 1 10-01-2006 11:08
Writing and Images on Inventor Designs Jan Olligs Inventor 0 23-02-2002 11:44
