Go to Post Man, I never thought I'd have to cite a rule during the offseason. - Karibou [more]
Unread 25-01-2009, 15:21
Adrien's Avatar
Adrien Adrien is offline
FRC #1414 (IHOT)
Adrien is an unknown quantity at this point
Send a message via MSN to Adrien
Screwing Encoder into Encoder Mount?
How are you guys mounting the encoder onto the Encoder Mount?
First of all, the screws that come with the encoders are thicker than the holes for them in the encoder mount. I suppose one could tap the holes in the encoder mount to screw in the screws, but we don't have a tapping tool that small.
Also, I guess you could drill out the holes in the encoder mount so the screws can fit in them, but then the screws aren't long enough to put a nut on the other side of the encoder mount. In which case one would need to get longer screws of the same thickness. I checked Home Depot, which didn't carry screws that thin, and Radio Shack, which didn't have screws at all...
So any hints?
Unread 25-01-2009, 15:31
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Re: Screwing Encoder into Encoder Mount?
Go to this site and it tells you how to do it (scroll down the page a bit to find instructions). I just ran into a similar problem, and this actually does work after you try it a couple of times. Be VERY careful while doing this though so you do not damage the encoder board. It seems to me that the bracket hole to mount the encoder board to are a bit narrower then they should be, but if you thread the screw in a bit sideways into the mount then it will work, once again be careful!
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 25-01-2009, 15:35
ironbears ironbears is offline
Alex@854
AKA: Alex
FRC #0854 (Ironbears Team 854)
ironbears is on a distinguished road
does anyone have a problem converting the .stp file from andymark to the .dwg used by autodesk? how is it done
Iron Bears Team 854
Rookie Year 2002
2008 ON Xerox Creativity
2007 WAT Rockwell Automation Innovation in Control
2007 WAT Regional Finalist
2007 ON Motorola Quality
2007 ON Regional Finalist
2006 ON Motorola Quality
2005 ON RadioShack Innovation in Control Award
2005 WAT RadioShack Innovation in Control Award
2003 ON Delphi "Driving Tomorrow's Technology"
2005 The Championship Event (4/21/2005 - 4/23/2005)
2003 The Championship Event (4/10/2003 - 4/12/2003)
Unread 25-01-2009, 18:14
Kyle Love's Avatar
Which file are you referring to (as in which part)?
Kyle Love
Teams I've been on:
How to mount rotary encoder Logan Williams Electrical 13 12-01-2009 20:00
HELP US BANEBOTS 56mm Gearbox Mount Encoder bhenry677 Electrical 3 05-09-2008 13:47
pic: Rotary Encoder Mount Madison Extra Discussion 8 10-03-2008 21:44
Turning a gear-tooth sensor into a quadrature output encoder Jared Russell Programming 4 18-01-2006 22:19
encoder.c Gary Bonner Programming 2 14-01-2005 13:41
