Go to Post your robot may have a bit of a "pimpwalk" - GMKlenklen [more]
Unread 25-01-2009, 19:28
Seat Ninja's Avatar
Seat Ninja Seat Ninja is offline
Still waiting for the boltstretcher
FRC #0686 (Bovine Intervention)
Seat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of light
Send a message via AIM to Seat Ninja
Turret Rotation Sensor
I was wondering how teams in the past (or this year) measured the rotation of their turrets, I.E. what sensors they used. I would say encoders, but there's the whole problem with the turret getting turned while the robot's turned off. Any help would be great, thanks.
Can you play Crysis?
Unread 25-01-2009, 19:36
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: Turret Rotation Sensor
We are using a potentiometer. Using a pot should allow you to find a center regardless of if your turret was turned while it was off. Be very careful with side loads though. Pots hate side loads and tend to stop working after experiencing them.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 25-01-2009, 19:41
Seat Ninja's Avatar
Thanks for the fast response. Where would you get this potentiometer? I an assuming it would be continuous rotation and mounted on the rotation motor.
Unread 25-01-2009, 19:42
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
We're using one of those grayhill encoders (stole this one from our 2007 robot until we buy one)... here's the mount we made yesterday for it:
It's slightly spring loaded since the belt isn't exactly sticky. When the robot is turned off, it's very easy to rotate the turret, so before each match we simply turn it to whatever its initial position is going to be and start. We'll also have reset limit switches so if for some reason it randomly slips it'll still be able to "fix" itself.
Unread 25-01-2009, 19:55
Gdeaver Gdeaver is offline
FRC #1640
Their are absolute rotary position sensors that can measure the magnetic field orientation of a magnet. They give an analog output proportional to the angular position. Cherry electronics has a nice automotive grade unit that is better than a continues rotation pot. Mouser carries them.
http://www.mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMvhQj7WZhFIAPb0P%2f L5OpbJhxqh3niR4xw%3d
The nice thing about them is they always give absolute position.
Unread 25-01-2009, 20:22
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
Absolute encoders can be a lot nicer than continuous pots, but a cheaper solution is to just have your turret turn towards a limit switch at the beginning of the math, and zero your encoder when it hits the switch.
Unread 25-01-2009, 20:34
Jared Russell's Avatar
Taking a year (mostly) off
This is a nice approach because if there is slip between the sensor and turret, the limit switch will correct for it.
Also, a lot of the advantages of absolute position-sensing sensors are lost once you have a reduction between the turret and the sensor (unless you have a multi-turn pot).
Kit Gear Tooth Sensor, rotation and where to get more Andrew Bates Electrical 3 07-01-2008 12:48
Continuous turret jjdebner Motors 10 05-02-2007 11:19
animating rotation negfrequency Inventor 6 28-12-2006 19:19
Rotation Systems Goaliexam Technical Discussion 9 06-06-2006 17:56
Turret or No Turret? Leo 1529 Technical Discussion 5 16-01-2006 15:47
