Go to Post This is a community that builds people as well as knowledge. - Karibou [more]
Unread 25-01-2009, 20:21
PackersFan PackersFan is offline
PackersFan is an unknown quantity at this point
Re: [FTC]: [FTC]: RobotC Template Problem (causing an FMS issue) and Potential Servo
Originally Posted by jbbjjbt View Post
What we do is
1) Move our bucket to the first position and make a mark on each of the servo holders
2) Move our bucket to the second position and make another mark of a different color on each of the servo holders
3) Take off the bucket and adjust the servos (Numbers in move servo command) until each one goes to the marks when told
4) Put the bucket back on and test. You may have to turn on the robot and run the servos to one position and then attach your bucket to get it lined up. The servos should be nearly silent if the numbers are correct. If there is alot of vibration or they move really jerky try again.
Could you go into more detail about that method? What I'm getting from the first and second positions is the starting point and the ending point, is that right? Also, where do the marks go and what purpose do they have?
[FTC]: LabVIEW Programming Template for FTC Team 288 FIRST Tech Challenge 30 06-02-2010 17:49
[FTC]: RobotC Template gdo FIRST Tech Challenge 14 10-11-2008 06:26
[FTC]: First problem with FTC and LabView.....? PhilBot FIRST Tech Challenge 5 07-11-2008 10:36
[FTC]: FTC Controller Station Connectivity (Bluetooth and USB) Issue jbbjjbt FIRST Tech Challenge 6 05-11-2008 11:49
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
