Go to Post Dean's probably sitting in his chair saying "Dance puppets, dance!" - [more]
Unread 25-01-2009, 20:22
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
Re: Turret Rotation Sensor
Absolute encoders can be a lot nicer than continuous pots, but a cheaper solution is to just have your turret turn towards a limit switch at the beginning of the math, and zero your encoder when it hits the switch.
Unread 25-01-2009, 20:34
Jared Russell's Avatar
Taking a year (mostly) off
This is a nice approach because if there is slip between the sensor and turret, the limit switch will correct for it.
Also, a lot of the advantages of absolute position-sensing sensors are lost once you have a reduction between the turret and the sensor (unless you have a multi-turn pot).
Kit Gear Tooth Sensor, rotation and where to get more Andrew Bates Electrical 3 07-01-2008 12:48
Continuous turret jjdebner Motors 10 05-02-2007 11:19
animating rotation negfrequency Inventor 6 28-12-2006 19:19
Rotation Systems Goaliexam Technical Discussion 9 06-06-2006 17:56
Turret or No Turret? Leo 1529 Technical Discussion 5 16-01-2006 15:47
