Go to Post But we all just have to do what we can and are willing to, to keep our teams going. - Adrienne E. [more]
Unread 24-01-2009, 12:01
team2491 team2491 is offline
FRC #2491
team2491 is an unknown quantity at this point
Driver station problem
We're relatively new to FIRST, so maybe our problem is stupid, but here it is: a few days ago, us electrical/programming people left the robot after a good day. At that point, we had a simple program to pretty much match motor speeds to joystick position. Coming back the next day, we found it didn't work- the motors didn't turn when the joysticks were pressed. We pinged everything, and everything but the driver station itself responded; after a couple hours of deliberation, we have come for help. Our driver station appears to be working fine, but it's displaying Battery: No comms and isn't talking to either our driver station router or the computer itself. Haven't gotten a ping returned from it under any conditions since yesterday. Thanks!
Unread 24-01-2009, 16:12
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Driver station problem
Did you build and deploy an application to the cRIO and set it to "run at startup"? If not, you'll need to reconnect to the cRIO via laptop or PC (through the DS-side router is fine) and download a new application.
Without build/deploy/"run at startup", the cRIO will always lose its code during a power cycle (hence the DS display of "no code").
I'm guessing that this is your issue. You might want to check out the LabVIEW reference docs here -
http://www.usfirst.org/community/frc....aspx?id=10934
Russ
Unread 24-01-2009, 21:26
Can you try connecting the ethernet cable from the computer to the other Driver Station ethernet port, and see if a ping succeeds? Maybe one (or both?) of the ports on the DS has fallen victim to a static electricity event.
Also, make sure the team number is set properly on the DS. I hate to suggest voodoo solutions, but it might be worth trying to set the team number again even if it shows correctly on the display.
Unread 25-01-2009, 21:46
FRC #2491
No, I'm pretty sure it has an application on it just fine, and the Driver Station displays "no comms" not "no code".
Both ethernet ports are experiencing the same problem. The team number was set properly, and we tried changing it to a different number and changing it back. Thanks for trying to help, though.
Does anyone else have any other possible suggestions?
Unread 25-01-2009, 21:57
rjmah rjmah is offline
rjmah will become famous soon enough
Did you already do the DS update using USB memory stick? I'd try redoing it.
Robert Mah
Team 1246 Agincourt Lancers
Unread 26-01-2009, 17:37
FRC #2491
Tried it and failed again. Thanks, though
Unread 30-01-2009, 17:44
FRC #2491
We ordered a replacement driver station, and it was DOA. The logo appeared intermittently on a reboot, then nothing else. Now only the LCD backlight comes on, but nothing else.
Does anyone have any ideas on keeping a DS alive? Obviously the replacement will go back under warranty, but we need to keep going.
thanks
Unread 31-01-2009, 00:18
Update 7 has a requirement to ground the board to the metal case. They are also static sensitive, so avoid being on carpet when you are using the driver station.
Robert Mah
Dead Driver Station? tdeprince FRC Control System 3 12-02-2009 12:14
Problem Downloading Program from WindRiver to Driver Station The_Laughing_ManMII C/C++ 10 09-01-2009 20:03
Driver Station Blank Screen, Anyone have the same problem? LDavies562 FRC Control System 14 22-12-2008 19:34
Driver Station Help.. 1708xMr.Roboto FRC Control System 8 22-12-2008 15:24
Driver Station Setup?? Team 1708 Dave Programming 9 19-12-2008 23:09
