Go to Post Now, most of the replies are very tactful when they are questioning a teams' design... but some are simply stupid. Keep your heads. - Andy Baker [more]
Unread 25-01-2009, 17:33
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
Saving feedback to a flashdrive
Hi, our team was talking about having our camera relay live feedback of it's view during competition to our website. The day we tested out the camera it lagged so badly doing a 1st person driving test that I crashed into a large object. So I remembered that we used a flashdrive to upload the new DS firmware so i was wondering. Would it work/Would it be FRC legal to have a flashdrive plugged into the DS saving camera feedback (and possibly other feedback) on the flashdrive for later uploading to a webiste or for reviewing purposes?
If someone could help me that'd be great. Thanks in advance!
The system is down.
Rockford Robotics 2039: Think outside the bots.
Unread 25-01-2009, 19:12
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Re: Saving feedback to a flashdrive
Nope. Sorry. I wish.
The flashdrive access is reading from the flashdrive, and is only for updating the DS. We don't have access to any writing (or reading) functions for the DS.
Unless I'm horribly mistaken. If you can figure out how to do it without modifying the DS firmware, I'd be interested.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 25-01-2009, 19:31
Originally Posted by MiniNerd24 View Post
Hi, our team was talking about having our camera relay live feedback of it's view during competition...
Be aware that the network will be blocking the live camera feedback on the competition field. Whatever you figure out for saving the video will be of no use without it.
Unread 25-01-2009, 19:32
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Why not write data to the cRIO's solid state "disk"?
Russ
Unread 25-01-2009, 20:21
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Russ
We did some tests early in the season when we were tuning our target colours where we saved a couple hundred 160x120 JPGs to the cRio. It took quite a while to save even those tiny images. I think having a thread saving images would greatly hurt your performance in the match.
On the other hand, you could have a button your drivers could press to take a snapshot (frcWriteImage in WindRiver), then maybe collage it with your own video of the match.
And I believe there has always been a rule saying that teams could strap a video camera to their robot for marketing/documentary purposes, though it'd probably be counted in your weight budget.
Unread 25-01-2009, 20:36
MiniNerd24's Avatar
So we it'd be advisable to skip trying to save things to the DS and instead save to the cRio for small things>?
The system is down.
Unread 25-01-2009, 22:02
Since the DS isn't programmable, you're essentially out-of-luck on the driver side (except for twiddling some outputs and using a custom circuit to store data transitions, yuck).
You could have the Dashboard PC record every packet of data sent from the robot. That would be easy but is limited to about 1k bytes at 50 times/sec. Could be very useful but won't be terribly good at storing a video stream.
You should be able to store many megabytes directly in the cRIO but I'm not sure about update rate. Maybe you can store pictures in RAM and dump them to nonvolatile memory later on?
Russ
Unread 25-01-2009, 22:08
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Incorrect. See here.
The standard live video ports on layer 3 will be disabled, but the video can be deconstructed, sent in packetized format to the dashboard, and reconstructed.
It will, of course, be horribly delayed and take up much of the cRIOs processor power.
If the OP is just looking to record the match through the 'eyes' of the robot then saving to an onboard system (the cRIOs flash or an external device) would probably be the best bet.
___________________
- Tennyson, Ulysses
Daylight saving time Vince lau Chit-Chat 10 02-11-2007 14:58
Saving Seats Karthik General Forum 58 05-05-2006 13:04
Inventor Problem w/ saving Pat Roche Inventor 2 14-02-2005 21:36
Saving Pics Jeffel Chit-Chat 9 23-01-2005 13:09
Time Saving Idea archiver 1999 1 23-06-2002 22:19
