Go to Post It is sad when the robots do not perform as we designed them. It is sadder still, when they perform well, but they are not victorious. However, it is most saddening when they win at a competition, and competitors are unwilling to acknowledge the teamwork and good fortune of the alliance. - Bill Moore [more]
View Poll Results: How fast does your camera tracking run?
1-3 hz 2 3.39%
3-6 7 11.86%
6-9 hz 4 6.78%
9-12 hz 17 28.81%
12-15 hz 7 11.86%
15-18 hz 1 1.69%
18-21 hz 6 10.17%
21-24 hz 2 3.39%
24-27 hz 1 1.69%
27-30 hz 12 20.34%
Voters: 59. You may not vote on this poll
Unread 25-01-2009, 22:54
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Re: Speed of the camera
Originally Posted by Daniel_LaFleur View Post
And how do you plan on sending the data to the cRIO?
You are not allowed (this year) to tap into the ethernet port on the camera side nor are you allowed to use the serial port (*SIGH*).
You could use a couple of digital IO pins as a serial port. It's been done before...
I observed (on the browser-based camera GUI) that making the image slightly out of focus improved the frame rate. I'm not sure if this is something you would want to do in competition or not.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Speed of axis camera nickmagus C/C++ 6 18-01-2009 18:25
Drive Control, Wheel Speed Calibration, and Rapid Speed Changes 7-11number1 Programming 3 23-01-2008 20:36
Tell the difference: 2007 CMU Camera, 2006, 2005 camera? Chris_Elston Programming 2 07-01-2008 13:11
What speed do you surf the net? Take the test! Elgin Clock IT / Communications 77 30-03-2005 16:28
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
