Go to Post Doesnt that sound like a McDonalds Item....Ya ill have a MacTablet with fries and a large Coke - Bill_Hancoc [more]
Unread 26-01-2009, 09:14
jrz126 jrz126 is offline
jrz126 is an unknown quantity at this point
Re: Accerometer Problems
We had a similar problem with ours. I believe it was a software issue. Unfortunitly I cant remember what I had to do to fix it.
You can verify the accelerometer is working by using a voltmeter. With the accelerometer hooked up, measure the voltage between the signal pin and ground. Be careful not to short anything out. If you measure something around 1.5V (+/-0.3V) then it is working.
Hope that helps.
Jeff
Unread 26-01-2009, 15:39
fordfiler6 fordfiler6 is offline
F2
AKA: Ford Filer
FRC #1559 (Devil Tech)
fordfiler6 is an unknown quantity at this point
When you opened the accelorometer, did you add scaling? The lack of scaling, or scaling thats off may throw your readings.
DS Problems popo308 FRC Control System 3 05-01-2009 22:16
OI Problems spc295 Technical Discussion 4 05-02-2008 09:44
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
PC problems. . . opnickc IT / Communications 5 12-01-2005 16:53
Problems- archiver 1999 0 23-06-2002 23:00
