Go to Post It keeps your minibot from being destroyed by Dean's chainsaw, which is a big competitive advantage in future matches. - Joe Ross [more]
Unread 25-01-2009, 20:52
Pancake Pancake is offline
FRC #0991 (The Dukes)
Team Role: Photography
Pancake is an unknown quantity at this point
Yet another Camera thread...
For the past few days / week, I've been trying to get the camera code to work. This code I have made is a variation of the sample code provided. As an FYI, the Target.h and Target.cpp is a copy and paste from the sample code.
The code *seems* to recognize a target... when it sees pink above green (or was it green above pink?), the servos slow down significantly and then once the target is out of sight, it keeps on moving at a normal speed.
Help is appreciated,
Thanks.
EDIT: Seems like "Track.h" needs to go after "TrackAPI.h". Still, there's likely something wrong w/ the code.
Unread 26-01-2009, 08:00
Mike Mahar Mike Mahar is offline
FRC #0138
Mike Mahar will become famous soon enough
Re: Yet another Camera thread...
The most likely case of this problem is that the sign of the horizontal direction is backward. When the two color demo sees the target it tries to step slowly until it is in the target is in the center. If the step value is backward it actually moves away from the target. Once the target is out of the image, the normal panning, which is faster, will kick in.
Unread 26-01-2009, 11:42
Do you mean changing:
incrementV = verticalDestination - verticalPosition;
to
incrementV = verticalPosition - verticalDestination;
Now I wish I read the comments
// TODO: Check to see if this needs to be reversed
// you may need to reverse this based on your vertical servo installation
Team Webmaster
Yet another bumper thread Vikesrock Technical Discussion 26 19-01-2009 17:04
yet another programming error hawk_11 Programming 2 13-02-2005 15:57
Yet another website to critique Joshua May Website Design/Showcase 11 18-10-2004 09:18
And yet, ANOTHER questions cammie825 Programming 8 13-02-2003 14:48
Yet another scoring system... archiver 2001 0 23-06-2002 23:26
