Go to Post I fear sometimes as time increases between the present and when someone started, some sight of just how hard it can be to field a functioning robot for a young team is lost. - xForceDee [more]
Unread 26-01-2009, 15:05
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
Increase Victor and Jaguar pulse resolution
I'm not sure who to target with this question, but I was wondering if the DIO module is capable being upgraded to a higher sampling frequency next near. I noticed that this year it has a sampling rate of 153kHz (which seems to be just perfect for 8bit resolution control for the Vics, Jags, and whatever other PWM devices one might use). Is there any talk of increasing the sampling frequency, or is the FPGA stuck with hardware limitations? Thanks.
Unread 26-01-2009, 15:19
Jared Russell's Avatar
Taking a year (mostly) off
Re: Increase Victor and Jaguar pulse resolution
For the Victors at least, there is no benefit in going to a higher pulse resolution. There are discrete digital steps used to control the output - the resolution of these are unchangeable.
For more information, see: http://www.ifirobotics.com/forum/vie...e12fb2 3c60f8
I can't speak about the Jaguar, though.
Unread 26-01-2009, 15:49
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The diligent coders at NI willing, the Jaguars won't even need PWM control next year, because we'll be using the CAN interface on them. And they'll be doing closed-loop position, velocity, and current control. With integral encoder and limit switches that you'll be able to get feedback from through the CAN bus. Assuming, of course, that the gods of the GDC and FIRST don't step in after kickoff with rules against using the CAN bus.....
Ahem. Anyways, the FPGA itself can support base clock rates up to 40 MHz, but actual loop rates depend on the code you're implementing. So only the NI gurus with the secret password know how much faster they could bump the loop rates.
Unread 26-01-2009, 15:50
Bryscus's Avatar
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Very interesting. Does anyone know if the Jaguar has discete steps as well?
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 26-01-2009, 15:54
Bryscus's Avatar
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Ok. Does the cRio even have a CAN interface? Or will it be part of another module? The only other interface I remember seeing is an I2C connection.
Unread 26-01-2009, 16:52
Since CAN is just a network protocol, I see no reason why the cRIO FPGA couldn't be configured to support CAN through either the ethernet or serial ports.
Unread 26-01-2009, 17:20
NI has two CAN modules available. I would assume that's what we would be given if FIRST decides to make the advanced abilities of the Jaguar open to us.
Unread 26-01-2009, 17:39
Your first statement is technically true, your second statement is not.
CAN in and of itself does not define the physical layer. However, it does define that the physical layer must have one dominant and one recessive state. Neither the serial port nor the ethernet port have this feature.
Additionally, "CAN" almost always implies a physical layer specified in ISO 11898-2. It is very possible to use other physical layers, but in conversation you would need to specifically mention you are doing something unusual.
In short, new hardware is required.
Unread 26-01-2009, 20:20
Gotcha. Thanks for the clarification!
Jaguar and wireless problems. Team_2547 FRC Control System 1 26-01-2009 16:54
Can I control a victor/jaguar with an RC receiver Bruceb Electrical 3 30-12-2008 10:50
Jaguar and Victor Flashing lights? programmr FRC Control System 24 17-12-2008 15:44
pic: Jaguar next to Victor ajlapp Extra Discussion 26 10-08-2008 17:56
[URGENT] NJ does Dean’s Homework - Assembly and Senate to vote on Resolution! EChang General Forum 3 11-02-2007 22:49
