Go to Post The mediocre do the minimum, then exclaim how easy it is. The exceptional never stop to gloat... they're too busy figuring out new ways to make it even better... - Mr. Lim [more]
Unread 26-01-2009, 16:49
rholokleolke rholokleolke is offline
First year programmer
FRC #0964
rholokleolke is on a distinguished road
Send a message via AIM to rholokleolke Send a message via Yahoo to rholokleolke
Help Getting cRIO Feedback
Our team is planning on using C++ in Windriver but we are having some problems. We aren't to sure on how to get feedback from the cRIO to the computer. In previous years we would have a serial cable running from the robot to the computer and we would print out diagnostic messages using IFI's terminal window. This year we aren't sure how to do that. I tried turning on the console out but I don't seem to get anything when I try to connect either through the terminal window in Windriver or through hyperterminal in XP. We can get code to compile and the debugger works but we would like to be able to see the readings from sensors plugged into the cRIO on the computer. Any suggestions. Thanks in advance.
First rule of technology if it doesn't work break it more.
Whos getting a second CRio lenny8 FRC Control System 17 12-03-2009 15:09
Getting Packets from the cRio rfrank Programming 2 17-01-2009 22:35
cRIO feedback Maxpower57 C/C++ 2 08-01-2009 19:06
Getting feedback from Axis Camera?? *programming in C++* Straberrie Programming 3 01-01-2009 22:39
Tricks getting the CRIO to talk to laptop mac7attack FRC Control System 10 08-12-2008 09:20
