Go to Post FRC is not worth giving up your grades. - Gregor [more]
Unread 26-01-2009, 17:57
Re: pic: Is this corner considered protected?
Well, you got your official answer.
http://forums.usfirst.org/showthread.php?t=11600
Unread 26-01-2009, 20:58
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
We figured if we turn the andle corner into a curve we could resove the problem but found the next issue.
Questions about the trailer hitch- I assembles a hitch like the one for the competition trailer (which is different than the team built trailer) and found that the small .615 dia. Hitch pin fits into a 1 inch x 1 inch square tube. There is only about 1 3/8 inch from the pin to the edge of the square tube. Will this limit the amount of turn that the trailer can make and if the aluminum hits the trailer hitch assembly (although it barley fits inside maybe if perfectly centered) will this be a violation of <R18> E..
We want to turn as sharp as possible so we can pin wheel around the trailer for defense.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 26-01-2009, 23:33
Scott Hill Scott Hill is offline
FRC #1625 (Winnovation)
Scott Hill is a splendid one to beholdScott Hill is a splendid one to beholdScott Hill is a splendid one to beholdScott Hill is a splendid one to beholdScott Hill is a splendid one to beholdScott Hill is a splendid one to beholdScott Hill is a splendid one to behold
Cory,
The Q&A answer you refer to follows:
Default Re: Bumper Length
1. The statements are not contradictory. The length of a BUMPER is determined by the portion of the assembly the includes all the required elements (pool noodle, fabric covering, clamping angles, and plywood backing) in the cross-section of the assembly. The length of this portion of the BUMPER assembly must be at least six inches. This is consistent with the previous answers and the statements/drawings in Team Update #2.
2. As indicated in Rule <R08-I>, all exterior corners of the BUMPER PERIMETER must be protected by BUMPERS. Both "sides" of the corner must be protected.
3. Rule <R18-E> requires that the ROBOT be designed such that contact between the ROBOT and the TRAILER (other than the Trailer Hitch) must be BUMPER-to-BUMPER. There are no exceptions to this.
To be honest I don't see here where it is abundantly clear that both sides of the corner must have their own BUMPER segment. It is clear that "all exterior corners of the BUMPER PERIMETER must be protected by BUMPERS." and that "Both sides of the corner must be protected." It is easy to create a ROBOT BUMPER PERIMETER which meets the the two statements in 2. above which has a side that does not have bumpers on it, yet the side would be protected. I believe the ROBOT in question at the beginning of this thread could be such a case. All it takes is two sets of oblique angles as part of the BUMPER PERIMETER.
Paul,
You quote ..."all sides must have a bumper"... GDC clarifications. I would like to know where you found that quote. In the Manual, in the team updates, and in the Q&A in it's many replies to questions on this topic I can't find where the GDC has stated "all sides must have a bumper". If any one has knowledge of where, in the above venues they have, please show me.
If you think about this.... if they really wanted each side of the robot to have BUMPER(S) they just have to include in the Competition Manual or the Team Updates the simple statement "all sides must have BUMPERS". When it would be so easy to state "all sides must have BUMPERS", they don't; not in the Competition Manual, not in the Team Updates, and not even in the many replies to questions in the Q&A. In my mind it is doubtful that in all of this communication, all of these communicators have randomly avoided using this simple statement if it clearly expresses their intent. Therefore I don't think it is the GDC's intent to require all sides of a ROBOT to have BUMPERS.
Paul, I look forward to seeing you, and your team and ROBOT at Midwest, and Cory, if things work out you and your folks as well at Nationals, the best of luck to us all,
Scott
Unread 27-01-2009, 00:01
Scott, this Q&A was posted early on. You also have:
http://forums.usfirst.org/showthread.php?t=10933
http://forums.usfirst.org/showthread.php?t=11056
http://forums.usfirst.org/showthread.php?t=11218
Take them all together or one at a time, Paul has summarized what the GDC has said.
Unread 27-01-2009, 00:07
Mike8519's Avatar
Mike8519 Mike8519 is offline
FRC #0303 (TEST Team)
Mike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really nice
While there is no rule saying all "sides" must have bumpers it must have corners to form that edge and by the Q&A responses those corners must be protected by 6" of bumper on each side. Extending noodles into the corner for protection does not count as both sides being protected.
EricH's final link explicity states this
Is this considered a hurdle? chaineezee Rules/Strategy 10 07-01-2008 19:12
Ballast considered extra parts? Gabe Rules/Strategy 9 12-02-2007 10:47
useing Copyright protected music. [527]phil Website Design/Showcase 15 22-10-2006 20:26
pic: Is this currently legal or considered exotic? CD47-Bot Robot Showcase 10 13-05-2003 01:09
Are Grommets considered fasteners? kmcclary Off-Season Events 1 04-11-2001 17:26
