Go to Post They improvised. They overcame. They persevered. And they succeeded. ... I cannot remember being more proud of a group of students with which I have been associated. - dlavery [more]
Unread 26-01-2009, 18:41
Lord Byron's Avatar
Lord Byron Lord Byron is offline
AKA: Tim Sebek
FRC #0538 (Dragon Slayers)
Lord Byron is an unknown quantity at this point
Jumper Connections
I feel stupid asking this, but where do we connect our jumpers for the axis camera? I know we connect one end next to the PWM cables on the digital sidecar, but I'm unsure about the other end.
Thanks in advance.
You have a ramen doctor in your secret ramen base!?!
Unread 26-01-2009, 18:48
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
Re: Jumper Connections
Yes, you are correct that one goes to the sidecar. the other connects to the 5v connection on your power distribution board - it's the little gray box next to the power indicator leds, at the end of the board where main power does NOT come in. The ethernet connect to the cRIO - I believe that is all the connections required.
CRUD Name: Windows
Alumni to Team: 350
Unread 26-01-2009, 18:53
Lord Byron's Avatar
AKA: Tim Sebek
The same 5 volt connection that is used to power the camera?
We considered that, but the fact that it was already connected to something and that it was 5 volt (not 6 volt as said in the manual) convinced us otherwise.
Unread 26-01-2009, 20:22
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
It sounds like you are asking where to connect the servos, not the camera.
Each servo connects to a PWM port on the Digital Sidecar. Then a jumper is installed to connect the two pins next to the PWM port together. For each servo you need a jumper on the two pins adjacent to the PWM.
Unread 26-01-2009, 20:43
Lord Byron's Avatar
AKA: Tim Sebek
I found our problem. What we had been working with was the jumper cables, not the plain jumper. Clearly, this caused a problem.
Benchtest Jumper Question Lord_Jeremy FRC Control System 1 07-01-2009 23:09
Ordering a center jumper BQuennell Electrical 3 27-02-2007 15:08
PWM 2 pin jumper mechanicalbrain Electrical 4 18-12-2005 18:09
Brake/Coast Jumper archiver 2001 3 24-06-2002 01:04
broken jumper on controller Mike Soukup Technical Discussion 5 22-10-2001 20:49
