Go to Post Oh and don't mind the lightening holes. Thats just how I waste time when I get bored :P - SerpentEagle [more]
Unread 26-01-2009, 19:04
Mr. E Mr. E is offline
Its physics or stamp collecting
FRC #1883
Mr. E is an unknown quantity at this point
Problem with tank drive
Hi. I basically am learning how to use LabView as i go along, so any help would really be appreciated. I am trying to set up a TeleopTankDrive.vi and a SolenoidControl.vi in hopes of, (obviously,) controlling the robot with two joysticks. I have verified that both joysticks and motors work. Now, here's my problem. Whichever joystick I have plugged into USB port one on the driver station controls both motors. It should only control one. The other joystick should control the other motor, however, it doesn't move either motor at all. When I first tried this, I had the second joystick plugged into USB port 2. I thought that maybe the USP port was broken so i tried port 3, however that didn't fix the problem. I attached my two programs. (Sorry about the quality though, it was too large a file as a .bmp) If you have any further questions about what I'm trying to attempt I will try to explain it better. Again, any help is appreciated. Thanks.
Tank Drive with Advanced Framework in Labview finman NI LabVIEW 4 30-01-2009 13:35
Help with programing Tank Drive in Lab View zackcool123 NI LabVIEW 3 18-01-2009 19:49
Tank Drive Idaman323 Programming 14 15-02-2005 09:01
Major problems with tank tread drive Lord Nerdlinger Technical Discussion 13 23-02-2004 21:15
Problem with drive train. Tton General Forum 2 12-02-2003 22:37
