Go to Post Even in the eighties, driver practice won competitions. - Brian Maher [more]
Unread 26-01-2009, 19:22
Brianu98 Brianu98 is offline
FRC #1493
Brianu98 is on a distinguished road
KOP won't constrain in inventor
Hey, does anyone know why none of the parts on the first base website constrain in inventor. Once you put one constraint on each part it gives you errors for every subsequent one. This makes it very difficult to lock parts in place. If anyone has any idea why this is happening please let me know ASAP. Thank you.
Unread 26-01-2009, 21:52
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
Re: KOP won't constrain in inventor
Which parts are you talking about? We haven't had problems with any metal parts but some of the electronics parts are molded so that their sides are not orthogonal. You can't use multiple flush constraints - you can usually only use the bottom. Make holes and constrain them that way. While it may seem like a bit more work now, at least you won't forget to put in all the parts later.
We use a lot of 8020 and there is only a tiny flat that is suitable for flush constraints. Also, Inventor 2009 seems to take much longer than 2008 did to calculate constraints. It helps to pick the least complicated part first to minimize the calculation time.
Unread 27-01-2009, 15:59
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
we constrain to the holes, and have no problems
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 27-01-2009, 18:44
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
If the part is molded it probably has a small amount of "draft" to assist in removal from the mold. Draft is a small taper angle so the part is thicker towards the leading end when you remove the part from the mold. Draft can be hard to detect visually on a CAD tube. You have to measure the part to find it, especiaslly if you are using a perspective rather than a parallel view. If you are having draft issues either constrain to holes or use edges rather than surfaces.
ChrisH
Christopher H Husmann, PE
"Who is John Galt?"
Unread 27-01-2009, 20:21
MPG's Avatar
MPG MPG is offline
Tutu Man
AKA: Michael
FRC #1259 (Paradigm Shift)
Team Role: Electrical
MPG is an unknown quantity at this point
I happen to be having the same problem and have tried to constrain to edges and holes but nothing has worked for me. Any other help would be much appreciated.
Inventor help: Text won't show up RogerR Inventor 2 08-03-2007 10:24
2006 Inventor KOP? SpaceOsc Inventor 6 16-01-2006 14:10
KOP Chassis & Transmission Inventor 8 Files JVN Inventor 0 12-01-2005 15:00
AutoCad Inventor in KOP? Chris_Elston General Forum 7 08-01-2005 20:13
Cannot place constrain in Inventor Paul Marshall Inventor 9 05-02-2004 05:56
