Go to Post A person is not defined by what mistakes they make, but more so by what they do after they realize their mistake. - Andy Baker [more]
Unread 26-01-2009, 17:54
Mr.Macdonald Mr.Macdonald is offline
FRC #2272
Mr.Macdonald is an unknown quantity at this point
multiple definition Problem
I keep getting this error when ever I try to compile the attached code
"multiple definition of `global constructors keyed to FRC_userClassFactory()'"
File Type: cpp Motor.cpp (909 Bytes, 22 views)
File Type: h Motor.h (473 Bytes, 21 views)
Unread 26-01-2009, 18:33
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Re: multiple definition Problem
You're including "RoboDefs.h" twice, once in each file.
Try just including it once, or use code like this:
#ifndef RANDOM_VALUE_YOU_WONT_USE
#define RANDOM_VALUE_YOU_WONT_USE
#endif
Unread 26-01-2009, 18:43
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
I would recommend using the second method dem. mentioned - it's a good habit to get into. Basically, it checks to see if anything called RANDOM_VALUE_YOU_WONT_USE has been defined yet, via the #ifndef line - everything between it and the #endif is skipped if the symbol after it has been defined previously. If it has not been defined, it defines it (#define) and then does whatever. It helps keep code and such from being accidentally repeated. The RANDOM_VALUE_YOU_WONT_USE should be replaced with a unique and descriptive title, such as MOTOR_CLASS_SYMBOL for your motor header. One thing to be careful of - don't repeat a title, as it skip the code if it has been defined elsewhere first - (that's what it's meant to do in this case, after all - So just name it something you know wouldn't be used again - and don't worry about it being long (you'll only be typing it twice, after all)
CRUD Name: Windows
Alumni to Team: 350
Unread 26-01-2009, 18:46
FRC #2272
RoboDefs is shielded like you posted
...Code...
#endif
I have other files importing RoboDefs.h multiple times, and it works fine.
I will post my whole project (zipped) if needed
EDIT: Show I protect my .cpp files too
Unread 26-01-2009, 19:14
AKA: Matt Soucy
Maybe that'll help...
What's the term for the second method again?
It's also good for writing your own libraries...If you want to replace something with your own version, just #define to make it exclude the other file, then #include your own changed copy.
Unread 26-01-2009, 19:25
FRC #2272
Heres the whole project, I changed a few little things to no avail.
Unread 26-01-2009, 19:39
AKA: Matt Soucy
I can't find anything wrong with that...but then I don't have windriver with me either...
Anyone else get further on this?
Unread 26-01-2009, 21:06
mtndurbin mtndurbin is offline
Programming Mentor
mtndurbin is an unknown quantity at this point
The problem is that you have the following line in your RoboDefs.h
START_ROBOT_CLASS(Main);
This is a macro defined in RobotBase.h (for reference).
This macro should only be in your Main.cpp file, and at the bottom works.
Peter Rivera
Mentor, Team 662.
Unread 27-01-2009, 10:33
FRC #2272
Peter Rivera
Mentor, Team 662.
Did you get it to compile, I can't test now but that makes sense. but why couldn't I put it at the end to the Main.h?
EDIT: But inside the macro shields
Unread 27-01-2009, 19:45
FRC #2272
Putting the "START_ROBOT_CLASS(Main);" in the main.cpp allowed it to compile, but now I can't get the printing to work. It seems as though my code doesn't even run.
Is there another way to write the "Main" class?
Definition of orthogonal.... fhobart General Forum 9 08-01-2009 12:38
[FTC]: Multiple Programs or One Program with Multiple Auto Modes kevin51292 FIRST Tech Challenge 4 02-01-2009 20:37
definition of FUNCPTR shavol Programming 6 28-12-2008 19:00
Hosting multiple sites in multiple VMs EHaskins Website Design/Showcase 6 22-12-2007 01:09
multiple definition error in MCC/Linker (possible bug?) wun Programming 5 01-04-2004 17:49
