Go to Post How come so many engineering types don't understand sarcasm? :) - IndySam [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Unread 26-01-2009, 20:10
dqmot17's Avatar
dqmot17 dqmot17 is offline
Orange Hat
FRC #0247 (Da Bears)
Team Role: Webmaster
dqmot17 can only hope to improve
Send a message via AIM to dqmot17
LabVIEW Update 3?
The title of the site says THIRD MANDATORY UPDATE, yet the file says 2.0 and the description says second update. Anyone try this, compare it to the other one?
http://joule.ni.com/nidu/cds/view/p/lang/en/id/1180
2009 Championship Finalists & 3 Blue Banners
Unread 26-01-2009, 20:15
dqmot17's Avatar
Orange Hat
LabVIEW Update 3?
The title of the page says THIRD MANDATORY UPDATE, but the download says 2.0, and the description says second update. Anyone test it out, see if it's different?
Unread 26-01-2009, 23:08
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Re: LabVIEW Update 3?
I saw that page and have been wondering that myself. The FRC Software Updates page at WPI has Update 3 there now too, but it requires FRC_2009_v11d.zip, which I assume is in the LabVIEW Update 3.
If you change the 2.0 to 3.0 in the FRCLabVIEWUpdate download URL, it works, but I'd really not want to try to install it until the link is actually posted somewhere.
Edit:
Looks like NI actually has updated that page with the 3.0 download. I'm downloading it now, and I'll try it out tonight if it's not too late.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 27-01-2009, 04:00
leftylink's Avatar
leftylink leftylink is offline
Code always works the first time!!!
FRC #1318 (Issaquah Robotics Society)
leftylink is on a distinguished road
Downloaded and installed. The about screen tells me it's Version 3. Noticing a slight discrepancy in the cRIO image name (v11 instead of v11d), but I'll hope this isn't a problem unless we find out otherwise when we re-image the robot tomorrow...
Issaquah Robotics Society 1318
2009 Galileo Division Semifinalists - Great way to finish off my FIRST career and high school.
2009 Oregon Regional Champions - Great job, 1983 and 2635!
Unread 27-01-2009, 10:59
It's been fixed
Unread 27-01-2009, 11:00
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
What exactly does it do? And is it mandatory if we're using windriver?
Get yer robot source code here!
Unread 27-01-2009, 11:39
TDohse TDohse is offline
AKA: Thomas
no team (NI)
TDohse is an unknown quantity at this point
Whoops. v11 and v11d are actually the same file. v11d was the internal name of the final incremental update to public release v11. NI renamed it to "v11" but WPI kept "v11d".
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Here are the bug fixes from the read me file:
Fixed an issue in which the FRC robot project uses up to 10% of CPU overhead to communicate with the camera even when the camera is not in use. The Update Camera Status subVI in the FRC robot project corrects this issue. If you create a new FRC robot project, the Update Camera Status subVI appears either in the Image Processing While Loop of the Basic Robot Main VI or in the Vision Processing VI of the Robot Main VI. If you continue working in a project you created in an earlier version of the FRC software, the project does not contain the Update Camera Status subVI. If you want to use the Update Camera Status subVI in an existing project to correct the CPU overhead issue, copy the subVI from a new FRC robot project, then paste and wire the subVI in the existing project similar to how it is used in the new project.
Fixed an issue in which running the CompactRIO Imaging Tool on Windows Vista returns unexpected error 60.
Fixed an issue in which if you perform 4x decoding, the Rate output of the Get VI on the Encoder palette returns half the correct rate although the value of the Distance output is correct.
The update also includes a new cRio image.
Unread 27-01-2009, 18:44
dqmot17's Avatar
Orange Hat
Do we need to update the image when we get a new update?
Unread 27-01-2009, 19:27
ebmonon36's Avatar
If we do update the cRio with the new image, is there a DS update to go with that?
Unread 27-01-2009, 19:41
dqmot17's Avatar
Orange Hat
On the update page, check if the DS update is the same as the one you used when you updated.
Unread 28-01-2009, 01:06
Yes. Run the image update tool and you'll see the new V11 image available.
Unread 28-01-2009, 20:22
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Not sure if this is a bug, but after the update, LabView could not find the GyroDevRefToAnalogChannelDevRef.vi. This happened to me, and a member on Team Fusion.
If your team runs into this problem, the file can be located at:
C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\Robotics Library\WPI\Gyro
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 28-01-2009, 21:06
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
I also thought I should mention-
Update 3 includes a new "Get Alliance" VI which can return both the alliance, and the position of the alliance (not entirely sure what that is).
This helps eliminate one more switch from the robot.
Team 2052- KnightKrawler
Mentor and volunteer
Labview Update 2 available Andy Brockway FRC Control System 1 23-12-2008 15:20
LabVIEW vs C/C++ 3DWolf Programming 11 05-12-2008 09:14
Labview tseres Programming 2 23-05-2007 00:27
