Go to Post I'm liking this. Programmers wont. But I will. :D - Rion Atkinson [more]
Unread 26-01-2009, 20:45
5n1p3r's Avatar
5n1p3r 5n1p3r is offline
IM 5n1p3r
AKA: Matthew
FRC #0714 (Team Panthera)
5n1p3r will become famous soon enough5n1p3r will become famous soon enough
Send a message via AIM to 5n1p3r
Exclamation 12 to 1 Bane Bots Planetary Transmission
Is the "12 to 1 Bane Bots Planetary Transmission" still available or in other words, is it still allowed for this years competition. I would appreciate any help
Unread 26-01-2009, 20:50
Re: 12 to 1 Bane Bots Planetary Transmission
The Banebots P80 (CIM) is available in 12:1, if that's what you're looking for. As a general rule of thumb, if it isn't restricted and it is available COTS, it is legal. (And the Manual has the entire list of restrictions.)
Unread 26-01-2009, 20:53
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
There are two of these. The ones from the 2007 KOP and the new model. Both are legal COTs. Make sure if you are using cad files from the 2007 KOP you get the right ones from banebots:
http://banebots.com/pc/Closeout/GP-56012 (the ones from 2007)
Banebots now normally sells their new model:
http://banebots.com/pc/P80K-nnnn-0005/P80K-43-0005
Both are legal and almost the same aside from a few differences. The CIMs mount differently and the output shaft on the old one is longer.
Mens et Manus
Unread 26-01-2009, 21:36
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
I don't believe that the 2007 Gear Box are legal this year. The part is no longer manufacturer and not available in a quantity that would be able to serve FRC teams. "Finding a few boxes" and offering them on closeout probably doesn't qualify. If you find this be different (through Q&A) please post because it would be nice to be able to use them.
The re-designed P80's IMHO are first legal.
Unread 26-01-2009, 21:38
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Careful with the distinction between the GP-56012 and GP-56012-HC gearboxes. FIRST has issued a Q&A with their opinion on the matter. (I'm assuming that their answer presumes that the gearboxes in question meet the conditions for being covered under <R32>, namely COTS parts from an old robot, or used-to-be-COTS.)
I don't know if the GP-56012 (e.g. from the 2007 kit) is available as a COTS item; this one, for example, doesn't specify the "-HC" anywhere, so it might be a COTS source for the GP-56012 to which the GDC referred. By contrast, BaneBots specify that the ones on closeout have hardened plates, and are therefore the GP-56012-HC versions.
There's a parallel discussion of similar issues happening here. It might be wise to wait until FIRST answers the question mentioned in that thread (from FRC57/Kevin Sevcik), before making a final decision on any parts that were at one time custom-ordered by FIRST for the KoP.
Unread 26-01-2009, 21:47
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Don't buy the GP-56012 model if you're planning on putting any kind of load whatsoever on this tranny. The -HC models have hardened carrier plates that are pretty good at dealing with fluctuating loads. The non -HC models have unhardened carriers and the output shaft will wobble out the hole in the carrier plate extremely quickly. If you don't already have the 2007 trannies laying around, save yourself a headache and go with the P80's.
DISCONTINUED: Bane Bots RS-550 Planetary Gearmotors Ice Berg General Forum 11 08-01-2009 09:43
Fisher Price Motor with Bane Bots Transmission Bochek Motors 8 04-01-2009 23:14
pic: Bane Bots Gearbox CAD roboticWanderor Extra Discussion 12 02-12-2008 01:47
Bane Bots Gear boxes not allowed? Skute327 Motors 4 13-01-2008 12:08
Bane Bots transmission sieze Demothesis Motors 3 31-03-2007 21:55
