Re: Quick release
I was thinking maybe the pneumatic actuator could be used, but I don't know how much force that would be able to hold. |
Re: Quick release
If you design it right, it can hold a lot. I know that 330 fired a short-throw cylinder into a winch powered by 2 FPs back in 2004 to keep us on the bar. We never had a problem with it.
Re: Quick release
1391 used a 1 inch pneumatic piston to hold back our launcher in overdrive. I think we had about 300lbs force held back by a simple lever actuated by the one inch piston.
Depending on the device you are trying to hold back, there are so many ways to do it with pre-made devices but I would recommend just throwing something together that does the job and that is simple and easy to make another one of at a competition. |
Re: Quick release
Could you PM me or provide me with more information as to how this winch system worked? We are very interested in this type of design. Thanks!
Re: Quick release
the equation is f=pa, or force = pressure x area. for the example above, in the extend direction it is f = 60 pounds / inch^2 x 3.14 (.375^2) = 26.49 pounds for the retract, you have to subtract the area of the internal rod, so the effective area is reduced (0.25 diameter = .125 radius) f = 60 pounds / inch^2 x (3.14 (.375^2) - 3.14 (.125^2)) = 23.55 pounds. |
Re: Quick release
Mod an Andymark Gen1 shifter, it has the release ability you're looking for as well as the ability to "wind up" whatever you're looking to build, if you do your design work right.
#7
Re: Quick release
you could just have a piston push all of the rope off of the open end of the reel.
#8
Re: Quick release
Fishing reel? Motor to wind, servo to release.
#9
Re: Quick release
http://www.chiefdelphi.com/media/photos/31538
http://www.chiefdelphi.com/media/photos/31539 you dont need pneumatics for quick releases.... ![]() |
#10
Re: Quick release
You could take a pipe, cut it in half and put it on a shaft, make a notch in one and and a reciprocating notch on the other, mount fasten the left side of the cut pipe to the shaft, use a pnuematic shaft to push the two pipes together while winding, then use the piston in the other direction to dislodge the pipe... If that makes sense.
Edit: 400th post. |
#11
Re: Quick release
I would use a small pneumatic actuator that came in the kit. We used this on a prototype to hot swap the trailer and it worked great even under tension.
#12
Re: Quick release
We are thinking of using a winch as well. We are thinking of having a winch to pull some cable back, which loads tension on some surgical tubing. Once tensioned, we plan on releasing a "clutch" that will disengage the winch and release the tension in the surgical tubing, thus kicking the ball.
#13
Re: Quick release
Fishing reel releases tend to lock when under load. Some of them lock very effectively even under a light load. AndyMark Shifters and other dog or meshing shifters are going to exhibit some amount of locking under load as well, simply because more load means more friction on the meshing parts. They probably will still be shiftable, but it's never going to be as easy as when they're unloaded.
| pic: Bike quick release part 2 | falconmaster | Extra Discussion | 4 | 24-01-2008 07:39 |
| Quick Vacuum Release | Calvin_1631 | Pneumatics | 8 | 05-02-2007 20:49 |
| Quick release wire harness | mechanicalbrain | Electrical | 2 | 08-01-2006 15:36 |
| openFIRST Release -- 'Twas the Release Before Christmas | Timothy D. Ginn | FIRST-related Organizations | 3 | 25-12-2003 23:44 |
| Quick release battery connector and 120 amps | n[ate]vw | Electrical | 6 | 18-01-2003 23:41 |
