Go to Post i do not TOUCH the robot. i don't even press the load button or the reset button. nooo touchy. but i like it better like that, this way, when something goes wrong, i can wholly blame the electronics ppl - nehalita [more]
Unread 26-01-2009, 21:34
Hastypickle's Avatar
Hastypickle Hastypickle is offline
AKA: Nicholas
FRC #1703 (Rats)
Hastypickle is an unknown quantity at this point
Question Quick release
Is there some sort of electronic quick release mechanism that we can use on a motor being used as a winch? I think I remember there being a mechanical one a couple years ago, but we got rid of it last year.
Unread 26-01-2009, 21:36
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Quick release
3 years ago we used a small pneumatic piston to pull a "grenade pin" from a mechanism at the start of the match; it was there for safety and we didn't want it released until nobody was near-by.
Unread 26-01-2009, 21:39
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Quick release
Any electronic mechanism is going to be illegal as an electronic solenoid or extra motor or something. So you'll need to go with some kind of mechanical quick-release. There's a rather lot of options, but it depends on how much load you're releasing and how you're winding up the load in the first place.
Unread 26-01-2009, 21:40
AKA: Nicholas
FRC #1703 (Rats)
Re: Quick release
We want to be able to set and release it multiple times throughout the match as we are using it for our ball scoring device.
Edit: We are using a fisher price motor to wind up the load. I'd estimate that it is about 15-25 lbs of force.
Unread 26-01-2009, 21:52
Gdeaver Gdeaver is offline
FRC #1640
Re: Quick release
You do have the hitec servos and FTC servos available. Could be used as an actuator for a drum brake. Multiple servos could be ganged together if the force of one is not enough.
Unread 26-01-2009, 21:55
Re: Quick release
I actually happened upon a ridiculously effective quick release based around an FP, a low ratio BaneBot planetary transmission, and a worm-wormgear set. With a servo with a cam to shift things. I can sketch something up in Inventor if you want to see how it'd work.
Unread 26-01-2009, 21:57
AKA: Nicholas
FRC #1703 (Rats)
Re: Quick release
Sure.
I was thinking maybe the pneumatic actuator could be used, but I don't know how much force that would be able to hold.
Unread 26-01-2009, 22:52
Re: Quick release
Originally Posted by Hastypickle View Post
Sure.
If you design it right, it can hold a lot. I know that 330 fired a short-throw cylinder into a winch powered by 2 FPs back in 2004 to keep us on the bar. We never had a problem with it.
Unread 26-01-2009, 23:08
KE5WGE's Avatar
KE5WGE KE5WGE is offline
FRC #1391
KE5WGE has a spectacular aura aboutKE5WGE has a spectacular aura aboutKE5WGE has a spectacular aura about
Re: Quick release
1391 used a 1 inch pneumatic piston to hold back our launcher in overdrive. I think we had about 300lbs force held back by a simple lever actuated by the one inch piston.
Depending on the device you are trying to hold back, there are so many ways to do it with pre-made devices but I would recommend just throwing something together that does the job and that is simple and easy to make another one of at a competition.
"Who makes the best mic pre for the money? You Do!"
Give me something to figure out and I'll break it. Give me another and I'll blow your mind.
Unread 26-01-2009, 23:15
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: Quick release
Sure.
at 60 psi, a 3/4" diameter cylinder has 26.5 pounds of force in the extend direction and 23.5 in the retract direction. If that is not enough, you can step up to a larger diameter.
the equation is f=pa, or force = pressure x area.
for the example above, in the extend direction it is
f = 60 pounds / inch^2 x 3.14 (.375^2) = 26.49 pounds
for the retract, you have to subtract the area of the internal rod,
so the effective area is reduced (0.25 diameter = .125 radius)
f = 60 pounds / inch^2 x (3.14 (.375^2) - 3.14 (.125^2)) = 23.55 pounds.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 26-01-2009, 23:25
CraigHickman
Posts: n/a
Re: Quick release
Mod an Andymark Gen1 shifter, it has the release ability you're looking for as well as the ability to "wind up" whatever you're looking to build, if you do your design work right.
Unread 27-01-2009, 08:55
qwertyuiop[]\'s Avatar
qwertyuiop[]\ qwertyuiop[]\ is offline
Drive Train/Manipulator Team Leader
AKA: Steven Harris
FRC #0623 (Cougar Robotics)
qwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of light
Re: Quick release
you could just have a piston push all of the rope off of the open end of the reel.
"...i told you i wanted the left-handed screwdriver not the right-handed one..." always let the mentors get their morning coffee or else they start getting angry and making stuff up.
2005 NASA VCU Website Excellence Award, 2006 NASA VCU Website Excellence Award, 2006 Capital Clash, 2006 Delaware FVC Regional, 2007 Ramp Riot, 2007 Virginia FTC Regional, 2008 NASA VCU Regional, 2008 Battle of Baltimore, 2008 Virgina FTC Regional
Unread 27-01-2009, 11:03
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Quick release
Fishing reel? Motor to wind, servo to release.
Unread 27-01-2009, 11:12
Aren_Hill's Avatar
Build Nifty Things
Re: Quick release
http://www.chiefdelphi.com/media/photos/31538
http://www.chiefdelphi.com/media/photos/31539
you dont need pneumatics for quick releases....
A guy who likes robots.
Unread 27-01-2009, 12:32
Chief Pride's Avatar
Chief Pride Chief Pride is offline
<3
AKA: James Kiefer
Chief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond repute
Re: Quick release
You could take a pipe, cut it in half and put it on a shaft, make a notch in one and and a reciprocating notch on the other, mount fasten the left side of the cut pipe to the shaft, use a pnuematic shaft to push the two pipes together while winding, then use the piston in the other direction to dislodge the pipe... If that makes sense.
Edit: 400th post.
pic: Bike quick release part 2 falconmaster Extra Discussion 4 24-01-2008 07:39
Quick Vacuum Release Calvin_1631 Pneumatics 8 05-02-2007 20:49
Quick release wire harness mechanicalbrain Electrical 2 08-01-2006 15:36
openFIRST Release -- 'Twas the Release Before Christmas Timothy D. Ginn FIRST-related Organizations 3 25-12-2003 23:44
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
