Go to Post We'll defintely be working on both the balancing 2 wheel robot, the 6 legged robot, and the wood chassis 8 wheel drive robot ideas this fall. - MrForbes [more]
Unread 26-01-2009, 22:44
aeasson aeasson is offline
FRC #2435
aeasson is an unknown quantity at this point
How to determine which alliance you are on?
Will there be a way that the autonomous mode software can use some information from the tournament control system to determine which alliance a robot is on? In other words how can we find out which target our camera should track without a downloading a new program at the start of each game?
Thanks
Unread 26-01-2009, 22:46
Jared Russell's Avatar
Taking a year (mostly) off
Re: How to determine which alliance you are on?
I too am interested in the answer to this question. It would eliminate the possibility of flipping the autonomous mode switch the wrong way...
Unread 26-01-2009, 22:48
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
You will get a match schedule that will list which alliance color you are on for each match. That's how you will know.
Unread 26-01-2009, 22:52
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
The typical way that this is done is through a switch mounted on your robot, which you set based on the alliance that you are on during that match. Your autonomous program then reads in the value of that switch at the start, and determines what camera code to load (or whatever it is that you're doing.)
I am however, interested in finding out if there is a way to get the alliance information from packets available to users from the field. I know this would take a lot of thought and picking through information, but I wonder if it's possible.
But the short answer is to simply use a switch.
Jacob
Unread 26-01-2009, 23:00
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Take a look at DriverStation::GetAlliance.
From DriverStation.cpp:
DriverStation::Alliance DriverStation::GetAlliance()
	if (m_controlData->dsID_Alliance == 'R') return kRed;
	if (m_controlData->dsID_Alliance == 'B') return kBlue;
	wpi_assert(false);
	return kInvalid;
If you look in NetworkCommunication/FRCComm.h, it seems that both alliance and position information is available in the control data packets.
struct FRCControlData{
	char dsID_Alliance;
	char dsID_Position;
Assuming this works properly, you should be able to use this on the field to determine your alliance color without a physical switch.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 26-01-2009, 23:10
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
There is a simmilar vi in the pending update . It gives alliance color and team position ( which I assume means the driver position)
Phil Malone
http://www.GEARSinc.org
Unread 26-01-2009, 23:13
FRC #2435
Thanks
The C++ code is the type of information I am looking for.
Can I get to similar data within Labview?
Unread 27-01-2009, 00:33
MattD's Avatar
Originally Posted by aeasson View Post
Thanks
I just installed Update 3 and I see there is now WPI Robotics Library > DriverStation > GetAlliance.vi.
Unread 27-01-2009, 00:48
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
We are using USER1 switch on the cRIO to switch the alliance. See the picture for an example
Unread 27-01-2009, 07:19
	wpi_assert(false);
	return kInvalid;
	char dsID_Alliance;
	char dsID_Position;
Nice! Thanks for the info.
Unread 27-01-2009, 20:35
FRC #2435
Thanks for the help
I am downloading update #3 and will try the Get Alliance vi on Thursday.
Unread 28-01-2009, 00:56
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
With the new vi you should be able to just replace the "Friend colors" enum with case structure and the "Get Alliance" vi. For testing, just use a switch on the console.
Below is the mod we will try.
Name:	Friend color.jpg
Unread 29-01-2009, 16:30
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Just something I noticed is that a switch is still helpful if you have several different types of autonomous programming depending on how you want to work with your alliance. I know that at Tempest N' Tampa, it would have been a mess if we and Pink only had a start position in the middle. But thankfully, Pink had 7 different autonnomous modes while we had 4. They were all lot more diverse in their modes, but we try.
Which Prompt are you using? 114Klutz 3D Animation and Competition 0 10-01-2007 19:32
So Which Competition Are You Going To Loki1989 Chit-Chat 4 13-02-2006 22:46
Which Side are you On? George A. Chit-Chat 16 24-05-2005 21:46
Which field are you watching? Katy Championship Event 24 12-04-2003 13:43
which regional are you submitting at?? Soukup 3D Animation and Competition 4 14-02-2003 18:25
